[mapguide-users] Schema Error
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Sep 13 03:33:32 EDT 2007
Studio does some checkups on references, it might be what is causing the
problem.
You should check that the mentioned file "SymbolDefinition-1.0.0.xsd"
exists.
Next step is to go to the http interface:
http://localhost/mapguide/mapagent/index.html
Click on "Resources" (top-left)  then "DeleteResource" (bottom-left).
Enter the full path of the item in question, ea.:
"Library//folder/mydatasource.FeatureSource"
Click "Submit".
If the same error appears, it indicates an error in your repository.
If all goes well, you should report the problem to Autodesk, as it is
purely Studio related then.
Regards, Kenneth, GEOGRAF A/S
Jorge Rubio skrev:
> Hi friends
> I would like to delete a data connection using MapGuide Studio 2007
> but it returns the following error.
> "An exception occurred in DB XML component.
> Error: the specified schema file is not found: c:\Program
> Files\MapGuideOpenSource\Server\Schema\SymbolDefinition-1.0.0.xsd
> File:c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\services\resource\xmlSchemaResolver.cpp
> Line:118"
> what is happening?
> Lic. Jorge Rubio
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070913/f9b25511/attachment.html
