[mapguide-users] KML from mapGuide , intagrete whit google maps.
Jason Birch
Jason.Birch at nanaimo.ca
Thu Sep 13 11:22:17 EDT 2007
If you're using PostGIS, the AsKML() function makes it pretty easy to
dynamically generate KML data. Even from polygons/lines/etc. Maps
tends to get confused with large features though. You might prefer to
use some kind of custom image tile instead. I think that Andy is doing
this.
Another approach is to use PHP files to generate the KML on the fly. I
believe that I posted an example of this at some point in the past,
based on initial work by Bob Bray back at the beginning of time... Here
it is
http://lists.osgeo.org/pipermail/mapguide-users/2006-March/000110.html
Jason
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Maciej
Skorczewski
Sent: Thursday, September 13, 2007 05:04
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] KML from mapGuide , intagrete whit google
maps.
hi!
Does anyone have try export layer from MapGuide to google maps?
It works great with Google Earth but i have problems whit place this
into my web map (google maps api)
What solution did you propose?
1. Generate my own KML file from shp files? (by using php) 2. Use
postgis function to get x,y of my polygon,polylines,point...and then
generate xml,textfiles or even kml....
3. ...or is there any magic function in MapGuide API to make this for me
have you make this before.
all my data use WGS84/LL84 coordinate.
