[mapguide-users] NULL value of DateTime property
Carl carlshe at 163.com
Thu Sep 13 12:13:35 EDT 2007
I face the same problem. Have you found the solution?
vaidasvel wrote:
> Hi, i have SDF where feature class has DateTime property which can be
> NULL.
> There is some objectswith that property set to NULL. When i try add this
> feature source to the map i get this error when dispaying the map or
> queriyng feature source programically: Invalid argument(s): [1] = "0" The
> year is invalid because it must be between 1 and 9999. Exception occurred
> in
> method MgDateTime.ValidateDate at line 1142 in file .\Data\DateTime.cpp
> Is there an easy and painless way to fix this?:)
> Pagarbiai,
> Vaidas Velutis
> Vyresnysis programuotojas, UAB „InfoEra“
> __________________________________
> Tel.: 8-5-2788456
> Faks.: 8-5-2784723
> Mob.: 8-699-85482
> S.Žukausko g.17, LT-08234, Vilnius
> El.paštas: vaidas at infoera.lt
> www.infoera.lt <http://www.infoera.lt/>  ; www.gps.lt <http://www.gps.lt/>
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/NULL-value-of-DateTime-property-tf3185103s16610.html#a12658287
