[mapguide-users] cannot insert feature,give a favor
Kenneth, GEOGRAF A/S
ks at geograf.dk
Mon Sep 17 02:47:48 EDT 2007
I belive that the reader.ToString() returns "MgByteReader", and does not
return the contents of the reader.
You must read the contents manually. I have replied to this particular
problem before, so search the list for a
solution on how to do that.
Regards, Kenneth, GEOGRAF A/S
knife skrev:
> private void set_ResourceWriteAble(MgResourceIdentifier resoureId,
> MgResourceService resourceService)
> String buffer;
> MgByteReader reader = resourceService.GetResourceContent(resoureId);
> buffer = reader.ToString();
> if (buffer.Contains("<Value>TRUE</Value>"))
> buffer = buffer.Replace("<Value>TRUE</Value>",
> "<Value>FALSE</Value>");
> Byte[] buf_Byte = System.Text.Encoding.Default.GetBytes(buffer);
> MgByteSource byteSource = new MgByteSource(buf_Byte,
> buf_Byte.Length);
> resourceService.SetResource(resoureId, byteSource.GetReader(),
> null);
