[mapguide-users] Tiling and other methods to improve performance
George McLean gmclean at gorge.net
Thu Sep 20 11:25:30 EDT 2007
Thanks again Kori. I will be upgrading today and hopefully will see
beautiful panning maps!
George
Kori Maleski wrote:
> George,
> Upgrade to 1.2, since the tiled maping/base layer performance is much
> better.
> Then use the tiling engine to pre-tile just the area of interest at large
> scales.  Small scales you may tile the whole thing.
> This will reduce the number of tiles significantly.
> The tiling engine allows you to specify a bounding box in tile row/columns.
> If you specify these bounds you can limit the tile generation to required
> areas only.  This will have to be done for each zoom threshold - easily done
> with a batch script.
> I generated a tiled base map for the entire state of California in this
> manner.  I tiled the entirety of all the small scale thresholds and then
> just specific areas of interest (urban centres) at large scale thresholds.
> To reduce tiles (and the amount of space they require) - try to reduce the
> number of thresholds.  Some may be unnecessary.
> Cheers,
> ________________________________
> Kori Maleski
> Senior Application Developer
> WEBSOFT DEVELOPERS, INC.
> P: (530) 759-8754 ext 114
> F: (530) 759-0923
> kori.maleski at websoftdev.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of George McLean
> Sent: Wednesday, September 19, 2007 3:32 PM
> To: MapGuide Users Mail List
> Subject: [mapguide-users] Tiling and other methods to improve performance
> Hello,
> I have a large base map that covers an area for an electric utility. The
> base map is in state plane grid coordinates and the map is about 100
> miles in both X and Y. Most of this map in this 100x100 region is blank
> since we only have base information near where the utility's facilities
> are located. I am trying to improve performance by using tiles. I would
> like to have zoom levels in pretty close, maybe on the order of 1:500 as
> well as zoom levels that much farther out. If I set this up with Base
> Layers in studio and then generate tiles using Websoft's tiling engine
> for each zoom level, I will get a huge number of tiles. If I do not
> generate tiles then performance is perceived as poor.
> Are there any better strategies for dealing with large base maps that
> must be viewed both at the detail level and high zoom scales? I m still
> using MGOS 1.1 (maybe I should upgrade).
> Thanks,
> George McLean
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
