[mapguide-users] Zoom to selection
Zac Spitzer
zac.spitzer at gmail.com
Fri Sep 21 04:15:46 EDT 2007
checkout around line 109 in
WebServerExtensions\www\schemareport\showgeom.php for a good example
On 9/21/07, Kenneth, GEOGRAF A/S <ks at geograf.dk> wrote:
> The only way I know of, is to issue a select of the objects on the
> datasource.
> While reading the objects, you can get their envelope (aka mbr, bbox,
> etc..).
> If you sum up alle the objects enevlopes, you can get the minimum rectangle
> in which all objects fit.
> Once you have this box, your center, will be the center of the box, and the
> scale will be the width or height of the box.
> Regards, Kenneth, GEOGRAF A/S
> Ivan Milicevic skrev:
> Hello,
> I wonder is it possible to calculate zoom extent on selected objects? For
> example, I have selected various type of objects (line, polygon, point) but
> I don't have any XY info in database on these objects. How can I calclate
> center point and scale in this case?
> Any help-advices are wellcome.
> Greetings,
> Ivan.
> ________________________________
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
http://zacster.blogspot.com/
+61 3 9018 5778 (voip via my pc)
+61 405 847 168 (aussie moible)
