[mapguide-users] Tiling and other methods to improve performance
Kori Maleski
Kori.Maleski at websoftdev.com
Mon Sep 24 14:33:07 EDT 2007
Working on MGO 1.2/ MGE2008 Release. Will have it up shortly.
Kori Maleski
Senior Application Developer
WEBSOFT DEVELOPERS, INC.
P: (530) 759-8754 ext 114
F: (530) 759-0923
kori.maleski at websoftdev.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel, Brian
Sent: Monday, September 24, 2007 10:55 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Tiling and other methods to improve
performance
I have a repeating error when I try to use the tilingengine
Title: Error
Message: Resource data was not found: LayerGroupData
StackTrace: Resource data was not found: LayerGroupData
Exception occurred in method MgTagManager.GetTag at line 395 in file
c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src
\services\resource\TagManager.cpp
Date/Time: 9/24/2007 1:52:08 PM
I am using 1.2
C:\Program Files\Websoft Developers\FacilitiesMap Tiling
Engine>"C:\Program File
s\Websoft Developers\FacilitiesMap Tiling Engine\FmTilingEngine.exe" -u
Administ
rator -p admin -m SoleburyTwp
Release Version 1.0.0
-u user: Administrator
-p password:***********
-m map: SoleburyTwp
-g group not specified
-s scale not specified
-sx not specified
-sy not specified
-ex not specified
-ey not specified
-l log not specified
Preparing to Tile 'SoleburyTwp' Map Definition...
Initializing Connection to MapGuide...Succeeded
Tiling 'Base Layer Group' Layer Group...
Scale: 1:98000 Finite Scale 1 of 12
Tiles: 20 ( 5 Columns x 4 Rows )
...1...2...3
Brian Berdel
McMahon Associates, Inc.
p: 215.283.9444
www.mcmtrans.com
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of George
McLean
Sent: Thursday, September 20, 2007 11:26 AM
Subject: Re: [mapguide-users] Tiling and other methods to improve
performance
Thanks again Kori. I will be upgrading today and hopefully will see
beautiful panning maps!
George
Kori Maleski wrote:
> George,
> Upgrade to 1.2, since the tiled maping/base layer performance is much
> better.
> Then use the tiling engine to pre-tile just the area of interest at
large
> scales. Small scales you may tile the whole thing.
> This will reduce the number of tiles significantly.
> The tiling engine allows you to specify a bounding box in tile
row/columns.
> If you specify these bounds you can limit the tile generation to
required
> areas only. This will have to be done for each zoom threshold -
easily done
> with a batch script.
> I generated a tiled base map for the entire state of California in
this
> manner. I tiled the entirety of all the small scale thresholds and
then
> just specific areas of interest (urban centres) at large scale
thresholds.
> To reduce tiles (and the amount of space they require) - try to reduce
the
> number of thresholds. Some may be unnecessary.
> Cheers,
> Kori Maleski
> F: (530) 759-0923
> From: mapguide-users-bounces at lists.osgeo.org
McLean
> Sent: Wednesday, September 19, 2007 3:32 PM
> Subject: [mapguide-users] Tiling and other methods to improve
performance
> Hello,
> I have a large base map that covers an area for an electric utility.
The
> base map is in state plane grid coordinates and the map is about 100
> miles in both X and Y. Most of this map in this 100x100 region is
blank
> since we only have base information near where the utility's
facilities
> are located. I am trying to improve performance by using tiles. I
would
> like to have zoom levels in pretty close, maybe on the order of 1:500
as
> well as zoom levels that much farther out. If I set this up with Base
> Layers in studio and then generate tiles using Websoft's tiling engine
> for each zoom level, I will get a huge number of tiles. If I do not
> generate tiles then performance is perceived as poor.
> Are there any better strategies for dealing with large base maps that
> must be viewed both at the detail level and high zoom scales? I m
still
> using MGOS 1.1 (maybe I should upgrade).
> Thanks,
> George McLean
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
