[mapguide-users] MapGuide integration with Google Maps
Maciej Skorczewski maciej.skorczewski at procad.pl
Tue Sep 25 07:39:26 EDT 2007
hi
if you add this to google maps you should use google api (it is much
easy as api in MG)
guestion is how many layers did you whant to show?
If one ex. parcels you should create KML or even simple txt file and put
it into google maps. Just use  (look into google API FAQ)
var geoXml = new GGeoXml("url_to_kml_files");
if you look on internet you should find many of examples how to use kml
files whit polygon,poliline etx. whit google maps.
Maciej Skórczewski
m.karam pisze:
> Hi
> If i add mapguide layers to google maps, will i able to use the mapguide
> viewer without any changes in my code ?
> thanks for your reply
> Karam
