[mapguide-users] speed issues
VladimirT vladimir.tsysar at hot.net.il
Tue Sep 25 04:55:46 EDT 2007
I have in my MG system for separate sdf file - separated data connection.
If you mean that the tile base layer- is a group sdf in one data connection?
How can i create Tile Base Layer that consist any sdf files?
What do you mean index in database- index in my tables in db ?
Regard,
Vladimir
macieksk wrote:
> Hi Vladimir!
> i have this same problem try this:
> 1. Use Tile Base Layer
> 2. Use index in your database (it should be faster access to data)
>> Hello,
>> We have big problem in the performance of the Mapguide :
>> 1.	When we add new layer via database connection its take forever.
>> 2.	When we open the web layout also its take to match time to open.
>>  How can I solve this problem?
>> Regard,
>> Shahar Levy
> pozdrawiam,
> Maciej Skórczewski
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/speed-issues-tf4509234s16610.html#a12875565
