[mapguide-users] Coordinate Systems
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Sep 27 14:58:15 EDT 2007
I am not 100% on the coordinate systems, but I have not found a way to
add coordinate systems.
You can generally use the EPSG code or WKT format for the maps.
The problem is that you cannot enter these codes in MapGuide Studio.
You have to change it in the Xml and then load the modified Xml back
into MapGuide OS.
If someone has an easier solution, please share :D
Regards, Kenneth, GEOGRAF A/S
Scott Hameister skrev:
> Does anybody have an answer on how to add missing coordinate Systems
> to Open Source 1.2 ....I too have a County Coordinate system In
> Wisconsin I'd like to have Mapguide OS recognize...I'm using Mapguide
> Studio where I can find the system, but it crashes using OS
> server...Where can we enter the codes in OS 1.2 so that the Authored
> Map sees them?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070927/d9f40733/attachment.html
