[mapguide-users] Deploying to site server = no map
Jackie Ng
jackie.ng at aecsystems.com.au
Fri Sep 28 02:55:50 EDT 2007
What is the zoom scale on the "invisible" map? Is it 0:001?
Could it be something like this?
http://trac.osgeo.org/mapguide/ticket/155
- Jackie
EmmaH wrote:
> Hi
> I get a viewer but no map.
> The layers are visible in the layers pane but several are 'ticked' as
> visible which is not in agreement with my startup settings. Almost as if
> it hangs in the middle of loading.
> If I try and 'select' something in the map frame there nothing to select
> (I wondered if the map was loaded but invisible but that doesn't seem to
> be the case).(So not the same situation as Takashige).
> Emma
> Jackie Ng wrote:
>> Hi Emma,
>> Do you get a viewer but no map? Or do you get a viewer but an error
>> message inside? Or do you get nothing at all?
>> - Jackie
>> EmmaH wrote:
>>> Hi,
>>> I have a mapguide 1.2 installed on my local machine and have built a
>>> mapguide application locally that works fine. I now want to deploy it on
>>> one of our servers. I have successfully installed mapguide but when I
>>> open the application everything looks fine apart from there being NO
>>> MAP!
>>> I installed mapguide 1.2 from the download files
>>> (MgServerSetup-1.2.0.exe and MgWebServerExtensionsSetup-1.2.0.exe). I
>>> copied the application files (under Webserverextensions/www) including
>>> the /bin and made this an application in IIS (.net version 2.0...). On
>>> my local machine I made a package.
>>> The mapadmin map administration works on the server. I loaded the
>>> package.
>>> I have hunted around but not managed to find any postings like this.
>>> Grateful for all suggestions!
>>> Emma
View this message in context: http://www.nabble.com/Deploying-to-site-server-%3D-no-map-tf4532104s16610.html#a12935595
