[mapguide-users] RE: MapGuide Automated Tiling Engine 1.2
Kori Maleski kori.maleski at gmail.com
Sat Sep 29 19:05:18 EDT 2007
The projection isn't supported.  I will post a fix this week and let you
know when it is up.
Cheers,
Kori Maleski
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Krunoslav
Sent: September 29, 2007 3:12 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: MapGuide Automated Tiling Engine 1.2
Kori Maleski-3 wrote:
> I have posted a new release.  Please download and install.
> I have bumped up the request delay to prevent the service from going
> unresponsive.
> The error that Maciek is encountering should now be written to the log
> file.
Hi Kori. Unfortunately, I still have some problems with automated tile
engine:
1. When I use Arbitrary X-Y coordinate system:
Title: Error
Message: LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
1],AXIS["X",EAST],AXIS["Y",NORTH]] coordinate system is not supported.
StackTrace:    at
SharpMap.Converters.WellKnownText.CoordinateSystemWktReader.ReadCoordinateSy
stem(String
coordinateSystem, WktStreamTokenizer tokenizer)
   at
SharpMap.Converters.WellKnownText.CoordinateSystemWktReader.Parse(String
wkt)
   at
SharpMap.CoordinateSystems.CoordinateSystemFactory.CreateFromWkt(String WKT)
   at FacilitiesMap.FacilitiesMap.Utilities.Tiling.GetUnits()
Date/Time: 29.9.2007 23:58:24
Title: Error
Message: Object reference not set to an instance of an object.
StackTrace:    at
FacilitiesMap.FacilitiesMap.Utilities.Tiling.GetTileCount()
2. When I use local projection (Gauss Krueger)
Title: Error
Message: Arithmetic operation resulted in an overflow.
StackTrace:    at
Date/Time: 30.9.2007 0:06:55
Title: Error
StackTrace:    at
Date/Time: 30.9.2007 0:06:56
Just to mention, map does work "manually". Tiles are being made when
browsing the map. It just doesn't work with automated tiling engine.
View this message in context:
http://www.nabble.com/MapGuide-Automated-Tiling-Engine-1.2-tf4517799s16610.h
tml#a12960488
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
