[mapguide-users] SDF 3 and MGOS 2.0
Bruce Dechant bruce.dechant at autodesk.com
Tue Apr 1 11:54:41 EDT 2008
Yannick,
Can you describe the join you are using?
Ie: Outer, Inner, 1-1, 1-many.
Could it be a case issue between the primary and secondary keys? Ie: CA != ca, but CA = CA (Join is case sensitive)
Are you using multiple join keys?
Is the SDF the primary and the Access database the secondary? (Most likely, but just want to confirm)
Any information you can provide would help.
Thanks,
Bruce
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Yannick Veillet
Sent: Tuesday, April 01, 2008 2:27 AM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] SDF 3 and MGOS 2.0
No, nothing!
-----Message d'origine-----
De : mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org] De la part de Zac Spitzer
Envoyé : mardi 1 avril 2008 09:52
À : MapGuide Users Mail List
Objet : Re: [mapguide-users] SDF 3 and MGOS 2.0
is there anything in the server error.log?
On Tue, Apr 1, 2008 at 6:47 PM, Yannick Veillet
<yannick.veillet at wanadoo.fr> wrote:
> Hi,
> I just have a problem when I want to read an SDF3 layer (FDO3.3) with MGOS
> 2.0. When I use join between SDF3 and ODBC Access table. It doesn't
display
> my layer...
> Is it normal?
> SDF3 without join is OK, what's wrong!
> Thanks for help!
> Yannick
>  mapguide-users mailing list
>  mapguide-users at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
