[mapguide-users] Adding custom tasks to Fusion template
Mike Adair madair at dmsolutions.ca
Tue Apr 1 14:16:27 EDT 2008
Don,
You first need to create <Widget> elements that will run your custom
tasks like so using the InvokeScript widget:
    <Widget xsi:type="UiWidgetType">
      <Name>task1</Name>
      <Type>InvokeScript</Type>
      <Extension>
        <Script>testScript()</Script>
      </Extension>
      <Label>menu label</Label>
    </Widget>
where the <Script> element is the JavaScript code to be executed when
the menu item is clicked.
Then to add these to the drop-down list in the TaskPane, you need to add
a reference to these widgets in the TaskPane menu container.  The ID of
the TaskPane menu container is the <MenuContainer> element in the
TaskPane widget.  Then in that container element add in pointers to your
InvokeScript widgets like so:
    <Container xsi:type="UiItemContainerType">
      <Name>TaskContextMenu</Name>
      <Type>ContextMenu</Type>
      <Item xsi:type="WidgetItemType">
        <Function>Widget</Function>
        <Widget>task1</Widget>
      </Item>
        <Widget>task2</Widget>
      </Item>
    </Container>
Where the <Widget> element corresponds to the <Widget><Name> elements of
your widgets.
Hope that helps.
Mike
Don C. MacGregor wrote:
> Hi all,
> I am running MGOS 2.0 with IIS and PHP on Win2003 using AJAX viewer,
> and now want to switch to fusion technology. Can someone please help
> by telling me how could I add my current custom tasks in AJAX viewer
> to task list of fusion template.
> Thanks
> Ask a question on any topic and get answers from real people. *Go to
> Yahoo! Answers.* <http://ca.answers.yahoo.com>
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
