[mapguide-users] Localizing menus and toolbar
Jim O'Leary jo at pat.ca
Tue Apr 1 14:22:00 EDT 2008
Kenneth
Are you talking about dynamically generating a web layout by opening a  web
layout XML file with placeholdrs in it, interpolating the strings for the
given language, and writing it to the session repository? Have you done any
work on this?
Thanks
Kenneth, GEOGRAF A/S wrote:
> Ok.
> I guess it would be simple to write a small app that loads the weblayot
> xml, translates the fields, and writes it into the session repository.
> Thanks for you reply.
> Regards, Kenneth, GEOGRAF A/S
> Chris Claydon wrote:
>> Unfortunately there's no way to do this yet. You'll need to create a
>> copy of your weblayout, and localize the strings it contains.
>> Chris.
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth,
>> GEOGRAF A/S
>> Sent: May 25, 2007 5:53 AM
>> To: MapGuide Users Mail List
>> Subject: [mapguide-users] Localizing menus and toolbar
>> Is there a way to localize the toolbar and menu's?
>> The current localizations work fine (except for the API default locale
>> problem), but only allows localization of "MapGuide" items, and not the
>> userdefined items. I would like to use a similar approach for having
>> multiple languages for the same WebLayout.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Jim O’Leary
Technical
Consultant
Pacific Alliance
Technologies
2nd Floor, 24 East 4th Ave, Vancouver
 BC, Canada
V5T1E8
TEL 604.676.6000 TOL 877.691.9171 FAX 604.682.0962
WEB  http://www.pat.ca/ www.pat.ca
View this message in context: http://www.nabble.com/Localizing-menus-and-toolbar-tp10801520s16610p16420567.html
