[mapguide-users] Test Fails with JSP Web Server Extensions
Salik
salikshaik at rediffmail.com
Thu Apr 3 14:10:39 EDT 2008
I have installed MGE 2008 on a Windows XP professional with Service Pack 2.
I am using an evaluation license at this point. I installed as a Site Server
and chose the Bundled Configuration to install Apache, PHP and Tomcat,
selecting Java as the development environment. I believe I made all the
changes required to configure for JSP. I have installed.
When I try to verify the configuration as noted in Verifying the
Configuration (REF: INSTALLCONFIGUREMGENTERPRISEONWINDOWS.PDF.pdf)
Testing the Map Agent - Test displays the XML document
Testing the Site Administrator - Site Administrator is displayed
Testing the Web Server Extensions - Got below error
Error:
Service Temporarily Unavailable
The server is temporarily unable to service your request due to maintenance
downtime or capacity problems. Please try again later.
URL Used to test Web Server Extensions
http://localhost:8700/mapguide2008/mapviewerajax/ajaxviewer.jsp?WEBLAYOUT=Library://ATest.WebLayout
Result:
Address:
http://192.168.1.4:8700/mapguide2008/mapviewerjava/ajaxviewer.jspajaxviewer.jsp?WEBLAYOUT=Library://ATest.WebLayout
Note:
Set the JAVA_HOME environment variable to point to my Java Installation
(C:\j2sdk1.4.2_16)
I did replace localhost with the IP address in httpd.conf file.
Added Apache Configuration in httpd.conf file
Verified the Tomcat Configuration and Connector Configuration
Thanks for any help on this!
Salik
View this message in context: http://www.nabble.com/Test-Fails-with-JSP-Web-Server-Extensions-tp16467960s16610p16467960.html
