[mapguide-users] Autodesk Mapguide and Vista?
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Sat Apr 5 10:18:53 EDT 2008
Ya, I've read that it's not supported - but that doesn't usually mean
that it doesn't work...especially with Autodesk. Often, it works fine
out of the box....and if not, you can tweak installation location or
modify the .msi file to make it work.....anyone actually managed to get
it working?
Andrew
Ivan Milicevic wrote:
> I had an answer from Autodesk, they said that Vista is not supported OS L
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Andrew
> DeMerchant
> *Sent:* Friday, April 04, 2008 8:39 PM
> *To:* mapguide_users at lists.osgeo.org
> *Subject:* [mapguide-users] Autodesk Mapguide and Vista?
> Anyone here gotten Mapguide Studio to work in Vista (x64,
> specifically)? It just crashes right away for me....I realize that
> this is sort of unrelated to MGOS, but this seems to be the most
> likely place to find an answer.
> Andrew
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
