[mapguide-users] SDF 3 and MGOS 2.0
Yannick Veillet
yannick.veillet at wanadoo.fr
Sun Apr 6 15:23:53 EDT 2008
I post my question differently : someone have already used a SDF3 layer with
ODBC join? Succesfull or not?
Thanks for helps!
Yan
-----Message d'origine-----
De : mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org] De la part de Yannick
Veillet
Envoyé : mardi 1 avril 2008 21:28
À : 'MapGuide Users Mail List'
Objet : RE: [mapguide-users] SDF 3 and MGOS 2.0
I'm using a very simple join : 1-1 and just one simple join key.
Key of my sdf3 (KEY*)= key of my access database field (Featd*)
I've got the same problem with all my sdf3 join to OBDC database.
Hope you understand...
Yannick
[mailto:mapguide-users-bounces at lists.osgeo.org] De la part de Bruce Dechant
Envoyé : mardi 1 avril 2008 17:55 À : MapGuide Users Mail List Objet : RE:
Yannick,
Can you describe the join you are using?
Ie: Outer, Inner, 1-1, 1-many.
Could it be a case issue between the primary and secondary keys? Ie: CA !=
ca, but CA = CA (Join is case sensitive) Are you using multiple join keys?
Is the SDF the primary and the Access database the secondary? (Most likely,
but just want to confirm)
Any information you can provide would help.
Thanks,
Bruce
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Yannick Veillet
Sent: Tuesday, April 01, 2008 2:27 AM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] SDF 3 and MGOS 2.0
No, nothing!
[mailto:mapguide-users-bounces at lists.osgeo.org] De la part de Zac Spitzer
Envoyé : mardi 1 avril 2008 09:52 À : MapGuide Users Mail List Objet : Re:
is there anything in the server error.log?
On Tue, Apr 1, 2008 at 6:47 PM, Yannick Veillet <yannick.veillet at wanadoo.fr>
wrote:
> Hi,
> I just have a problem when I want to read an SDF3 layer (FDO3.3) with
> MGOS 2.0. When I use join between SDF3 and ODBC Access table. It
> doesn't
display
> my layer...
> Is it normal?
> SDF3 without join is OK, what's wrong!
> Thanks for help!
> Yannick
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
