[mapguide-users] Data Package Problem
    Rahul
    unicorn_admirer at yahoo.com
    Wed Apr  9 00:47:39 EDT 2008
Hi ,
         I think you should check www/dotnetviewersample/ajaxviewersample.aspx file , this file contain the information regarding the weblayout as well as the startup page for the sample application.
<script runat="server">
String webLayout = "Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout";
String defaultUser = "Anonymous";
String defaultPassword = "";
String sessionId = "";
</script>
Max !!
----- Original Message ----
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Wednesday, April 9, 2008 11:33:13 AM
Subject: Re: [mapguide-users] Data Package Problem
Dear Rahul,
I use Asp.Net 2.0 and i load packages also but what is the start up page i set to run the application.
my WebLayout stored in C:\Program Files\MapGuideOpenSource2.0\Server\Packages\Library\Samples\Sheboygan\Layouts and the path which returned in JAvascript is  "Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout";
I can't understand from where WebLayout Picked.
Please help me.
With Regards,
Sandeep
On Wed, Apr 9, 2008 at 9:53 AM, Rahul <unicorn_admirer at yahoo.com> wrote:
Hi ,
         I think you try to check through MapAgent and see that you can get some xml output for the Feature Source loaded through Data Package(*.mgp).
http://x.x.x.x:8008/mapguide/mapagent/
One more thing are you using MapGuide Studio and if so then you can check the loaded package and see that you can preview weblayout or layers in the mapguide studio.
Max
Dear Rahul,
After i load data packages from site administrator and i run my application then i get blank output without any Error.
Please told me exactly what happen and which page i set to start up page for the mapguide application or there is any changes require in mapguide open source sample code.
Please help me.
With Regards,
Sandeep
You rock. That's why Blockbuster's offering you one month of Blockbuster Total Access, No Cost.
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
__________________________________________________
Do You Yahoo!?
Tired of spam?  Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080408/9cf5048d/attachment.html
