[mapguide-users] Data Package Problem
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Apr 10 03:06:48 EDT 2008
I would like to help you out, but if you do not follow the guide
strictly, it is very difficult to guess what went wrong.
I would suggest that you start over, and follow the guide closely.
If you do not want to do that, there are a couple of common reasons for
a 404 error:
1. The directory/file that IIS points to does not exist
2. ASPX/.Net is disabled in IIS
3. Scripting is disabled.
4. The folder is not mapped in IIS.
5. Permission problems may sometimes be masked as 404 errors.
6. Make sure that IIS is using .Net 2.0
I can't guess what you are refering to with "Administrative Tool ->
MapGuide -> DotNetViewerSample".
Regards, Kenneth, GEOGRAF A/S
Sandeep Thosar skrev:
> Dear *Kenneth,*
> *Thanks for the mail and tried as per your instructions and also give
> references in Administrative Tool --- > Mapguide ---->
> Dotnetviewersample.*
> *but it is not working and i facing the same problem.*
> *Then i type URL in internet Explorere--> *
> http://localhost/mapguide/dotnetsampleviewer/ajaxviewersample.aspx
> *but it gives me following error THE PAGE CAN NOT FOUND.*
> Please help me out.
> With Regards,
> Sandeep
> On Wed, Apr 9, 2008 at 6:51 PM, Kenneth, GEOGRAF A/S <ks at geograf.dk
> <mailto:ks at geograf.dk>> wrote:
>     In the guide, step 2 is:
>     2. Download and extract the sample application.
>         Visit the downloads page and download phpviewersample-2.0.zip.
>     *On Windows extract the files to C:\Program
>     Files\MapGuideOpenSource\WebServerExtensions\www*. On Linux
>     extract the
>         files to
>     /usr/local/mapguideopensource/webserverextensions/www. Note that
>     in both cases it should create a folder called phpviewersample
>     under www.
>     I have made the important part bold.
>     For dotnet, the folder is called dotnetviewersample instead of
>     phpviewersample.
>>     I refering the dotnetviewersamplecode from download page and then
>>     unziped the sample code to C:\Inetpub\wwwroot directory and when
>>     i clicked on this linked i get message page can't find and if i
>>     run my application then i get blank output.
>>     Please help me.
>>     With Regards,
>>     Sandeep
>>     On Wed, Apr 9, 2008 at 2:35 PM, Kenneth, GEOGRAF A/S
>>     <ks at geograf.dk <mailto:ks at geograf.dk>> wrote:
>>         What sample code are you refering to?
>>         If you try the link below:
>>         http://localhost/mapguide/dotnetviewersample/ajaxtiledviewersample.aspx
>>         It should ask you for username/password.
>>>         Dear  Kenneth, GEOGRAF ,
>>>         Thanks for the mail.
>>>         I After I installed data packages then it give me one log
>>>         file Sheboygan.mgp.log but when I run the sample code it
>>>         give me blank output again.
>>>         Please help me.
>>>         With Regards,
>>>         Sandeep
>>>         On Wed, Apr 9, 2008 at 1:09 PM, Kenneth, GEOGRAF A/S
>>>             Did you read the the guide?
>>>             http://mapguide.osgeo.org/2.0/documentation.html
>>>             Click on "Getting Started with MapGuide".
>>>             Which step is failing?
>>>             .Net/IIS uses slightly different urls:
>>>              http://localhost/mapguide/mapadmin/login.php
>>>             You seem to confuse repository paths with file system paths.
>>>             The WebLayout is not on the filesystem, but in the
>>>             repository, so you cannot find it from windows explorer.
>>>             You must use an authoring tool to edit the WebLayout
>>>             (links are in the guide).
>>>             For more information on how MapGuide works, please see
>>>             the Developers Guide:
>>>             Simply click on "MapGuide Developers Guide".
>>>>             Dear Rahul,
>>>>             Thanks for the information but when i debug this page
>>>>             it shows me UserId= Anonymous and Password="" then
>>>>             create session after that it goes to
>>>>             frame id="viewerFrame" frameborder="no" marginwidth="0"
>>>>             marginheight="0" scrolling="no"
>>>>             src="../mapviewernet/ajaxviewer.aspx?SESSION=<%=sessionId%>&WEBLAYOUT=<%=webLayout%>">
>>>>             where i get session information and shows WebLayout
>>>>             path
>>>>             Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout
>>>>             and then get blank output so where i stroes this
>>>>             Library folder in my application folder or currently it
>>>>             stored in C:\Program
>>>>             Files\MapGuideOpenSource2.0\Server\Packages\Library\Samples\Sheboygan\Layouts.
>>>>             Please help me.
>>>>             With Regards,
>>>>             Sandeep
>>>>             On Wed, Apr 9, 2008 at 10:17 AM, Rahul
>>>>             <unicorn_admirer at yahoo.com
>>>>             <mailto:unicorn_admirer at yahoo.com>> wrote:
>>>>                 Hi ,
>>>>                          I think you should check
>>>>                 www/dotnetviewersample/_*ajaxviewersample.aspx*_
>>>>                 file , this file contain the information regarding
>>>>                 the weblayout as well as the startup page for the
>>>>                 sample application.
>>>>                 <script runat="server">
>>>>                 String webLayout =
>>>>                 "Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout";
>>>>                 String defaultUser = "Anonymous";
>>>>                 String defaultPassword = "";
>>>>                 String sessionId = "";
>>>>                 </script>
>>>>                 Max !!
>>>>                 ----- Original Message ----
>>>>                 From: Sandeep Thosar <sandeepthosar at gmail.com
>>>>                 <mailto:sandeepthosar at gmail.com>>
>>>>                 To: MapGuide Users Mail List
>>>>                 <mapguide-users at lists.osgeo.org
>>>>                 <mailto:mapguide-users at lists.osgeo.org>>
>>>>                 Sent: Wednesday, April 9, 2008 11:33:13 AM
>>>>                 Subject: Re: [mapguide-users] Data Package Problem
>>>>                 Dear Rahul,
>>>>                 I use Asp.Net 2.0 and i load packages also but what
>>>>                 is the start up page i set to run the application.
>>>>                 my WebLayout stored in C:\Program
>>>>                 and the path which returned in JAvascript is
>>>>                 I can't understand from where WebLayout Picked.
>>>>                 Please help me.
>>>>                 With Regards,
>>>>                 Sandeep
>>>>                 On Wed, Apr 9, 2008 at 9:53 AM, Rahul
>>>>                     Hi ,
>>>>                              I think you try to check through
>>>>                     MapAgent and see that you can get some xml
>>>>                     output for the Feature Source loaded through
>>>>                     Data Package(*.mgp).
>>>>                     http://x.x.x.x:8008/mapguide/mapagent/
>>>>                     One more thing are you using MapGuide Studio
>>>>                     and if so then you can check the loaded package
>>>>                     and see that you can preview weblayout or
>>>>                     layers in the mapguide studio.
>>>>                     Max
>>>>                     Dear Rahul,
>>>>                     After i load data packages from site
>>>>                     administrator and i run my application then i
>>>>                     get blank output without any Error.
>>>>                     Please told me exactly what happen and which
>>>>                     page i set to start up page for the mapguide
>>>>                     application or there is any changes require in
>>>>                     mapguide open source sample code.
>>>>                     Please help me.
>>>>                     With Regards,
>>>>                     Sandeep
>>>>                     You rock. That's why Blockbuster's offering you
>>>>                     one month of Blockbuster Total Access
>>>>                     <http://us.rd.yahoo.com/evt=47523/*http://tc.deals.yahoo.com/tc/blockbuster/text5.com>,
>>>>                     No Cost.
>>>>                     _______________________________________________
>>>>                     mapguide-users mailing list
>>>>                     http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>                 __________________________________________________
>>>>                 Do You Yahoo!?
>>>>                 Tired of spam? Yahoo! Mail has the best spam
>>>>                 protection around
>>>>                 http://mail.yahoo.com <http://mail.yahoo.com/>
>>>         mapguide-users mailing list mapguide-users at lists.osgeo.org
>>     _______________________________________________ mapguide-users
>     mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080410/33ba3d9c/attachment.html
