[mapguide-users] King Oracle Problem
Luis Ramos LRRamos at aurensis.com
Thu Apr 10 04:18:57 EDT 2008
Hello,
I'm facing a similar problem on a XP machine with MagGuide Server 2.0,
Apache 2 and Oracle 9.2.
What I've done:
- downloaded and installed the King Oracle v.0.7.3 For FDO 3.3 with Oracle
Instant Client.
- downloaded and installed the Oracle Instant Client basic v 10.2.0.3
- changed the providers.xml file
- restarted the MapGuide Server
What do I get when creating a new data connection:
- on Autodesk MapGuide Studio 2008, shows the King Provider on the FDO list
but after selecting this, the connection properties are blank and non
editable.
- on AutoCAD Map 3D 2008, shows the King Provider on the FDO list but after
selecting this, I get an unable to create connection to provider
"King.Oracle.0.1.1".
If you managed to solve this problem please tell me how.
Luís Ramos
A H wrote:
> hello. i'm also currently facing the same problem. i'm using Oracle 9.2 as
> database. i followed the steps and i got this message when testing the
> connection in MapGuide Studio 2008:
> An exception occurred in FDO component.
> ORA-12705: Cannot access NLS data files or invalid environment specified
> what does that mean?
> my FDO version is 3.2.2. and i downloaded the v0.7.3 Windows 32-bit
> provider with Oracle Instant Client from the website. i copied the
> King.Oracle DLLs and Oracle instant clients DLL and put it in the FDO
> folder. is this definition correct for providers.xml?
> <FeatureProvider>
>     	  <Name>King.Oracle.0.1.1</Name>
> 	  <DisplayName>King Provider for Oracle</DisplayName>
>      	  <Description>Read/write access to spatial and attribute data in an
> Oracle Spatial.</Description>
>     	  <IsManaged>False</IsManaged>
>     	  <Version>0.1.1.0</Version>
>     	  <FeatureDataObjectsVersion>3.2.2.0</FeatureDataObjectsVersion>
>     	  <LibraryPath>C:\Program
> Files\MapGuideOpenSource\Server\Bin\FDO\KingOracleProvider.dll</LibraryPath>
> 	</FeatureProvider>
> i thought everything should be fine since MapGuide Studio is enable to
> display the providers but i got that message. i use
> //[host]:1521/[service] as the service name as mentioned in the Oracle's
> documentation.
> Simon Pelicon wrote:
>> Hi,
>> Which version of MapGuide do you have?
>> There are providers v0.7.3 for different FDO versions (3.1 ,3.2 and
>> .3.2.2)
>> Do you restart MG server after changing provider files,xml etc...?
>> You can also check which files are missing or wrong , using "Dependency
>> walker" http://www.dependencywalker.com/
>> With Dependency W. open KingProvider.dll.
>> Simon
>> JeromeA wrote:
>>> Hi,
>>> yes I think so. I took the first one: v0.7.3 Windows 32-bit provider
>>> with
>>> Oracle Instant Client.
>>> I'm trying to connect to Oracle 9.2.0.4.0 from MG Studio 2008
>>> Jerome
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/King-Oracle-Problem-tp14804675s16610p16604465.html
