[mapguide-users] ODBC problems....MGOS 2.0
Kenneth, GEOGRAF A/S ks at geograf.dk
Fri Apr 11 02:55:08 EDT 2008
It picks up the locale from your machine.
In the "About" dialog, you can see what the OS considers your locale.
You should be able to select English in the initial dialog.
I would like to find the cause for this problem, as that would be quite
annoying for most users.
What locale does the OS report?
Regards, Kenneth, GEOGRAF A/S
Jason Birch skrev:
> OK, so when I build MapStudioOS, most of the UI is in Spanish.
> I don't really care (pretty easy to figure out) but is there an easy
> way for me to set this?
> I'm using VS2005 by the way; seems to work fine.
> Jason
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of
> *Kenneth, GEOGRAF A/S
> *Sent:* Thursday, April 10, 2008 13:17
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] ODBC problems....MGOS 2.0
> I'm hoping it will be complete within the next week, but it's not a
> promise :)
> Andrew DeMerchant skrev:
> I don't have access to that - so I'll wait. How long till you release
> that? I know that's a tough question, but are we talking days, weeks
> or months?
> Andrew
> Kenneth, GEOGRAF A/S wrote:
> I have added the column stuff to MapStudio OS, but I have not yet
> built a new release.
> If you have access to a Visual Studio 2003 (or newer) it should be no
> problem to build one yourself.
> I am currently building an browser for unmanged resources, and I will
> release it after that.
> Ah! I had to change the MG Server service to run on the correct
> account.....though, I DID (prior to that) try (and fail) to enter the
> correct credentials right in the provider settings. anyway, that did
> it.....now on to the next problem:
> How the heck am I supposed to actually _make_ a new ODBC connection??
> In Autodesk Studio, I can at least now see my tables, and select which
> fields to use as the geometry fields (not so in MapStudioOS) - but
> when I try to save it, I get the following:
> I'd do it in MapStudioOS, but there doesn't seem to be a place to pick
> my x and y columns...And we all know that WebStudio's not so useful
> for this either....This "upgrade" to 2.0 sure is starting to feel like
> a bad idea.
> Andrew
> Dave Wilson wrote:
> The database connections are compatible and should work. Reasons why
> they might not work:
> When using connection strings the ODBC driver name is different
> between the machines or does not match the string. The DSN names are
> not the same or do not exist.
> Are the databases local to the server? If not did you change your MG
> server process to use an account with network access?
> Regards,
> Dave
> <mailto:mapguide-users-bounces at lists.osgeo.org>
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Andrew
> DeMerchant
> *Sent:* Thursday, April 10, 2008 8:44 AM
> *Subject:* [mapguide-users] ODBC problems....MGOS 2.0
> I'm trying to start to migrate to MGOS 2.0 (from 1.0.2)....I've got a
> test machine running MGOS 2.0 right now, and am testing out just
> moving my packages from my production server to my test server. Not
> surprisingly, any dataconnections I had set up on my production server
> stop working on my dev server - I assume because they were made using
> FDO 3.1, while MGOS 2 uses FDO 3.2 (it'd be awfully nice if the FDO
> people would make things backwards compatible). Anyway, I fully
> expected those to break (along with my Raster layers).
> I've hit a wall in trying to get them (my ODBC datasources) set up
> again. I've tried in Autodesk Studio, I've tried in MapStudioOS -
> neither are working. They both give me an error that is the same - "An
> exception occurred in FDO component. RDBMS: No current open
> database."....I've tried custom connection strings and DSN (which is
> my preferred method). Same result for both. I did successfully connect
> to an SQL server I have onsite, but that's not where my data is. That
> suggests to me the the problem may be with my database format - which
> is Jet (MS Access). What the solution here? If all else fails, is it
> an option for me to install FDO3.1 with MGOS2?
> Andrew
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
Skipped content of type multipart/related
