[mapguide-users] ODBC problems....MGOS 2.0
Kenneth, GEOGRAF A/S ks at geograf.dk
Sat Apr 12 13:11:07 EDT 2008
Very odd.
 From the screenshot it would appear that the file
MapStudio.ResourceEditors.FeatureSourceEditorBase.resx
is loaded as:
MapStudio.ResourceEditors.FeatureSourceEditorBase.es-ES.resx
On my system, MapStudio.ResourceEditors.FeatureSourceEditorBase.resx is
in proper english, and if I select english in the site dialog, all
dialogs are in english.
Did you run the "Update DEBUG environment.bat" ?
Regards, Kenneth, GEOGRAF A/S
Jason Birch skrev:
> I wonder if this is an artefact of me compiling in VS2005?
> I chose English, and it is reporting en-US in the About box.
> I just did a little more looking, and most of the screens (layers,
> maps, fusion apps) are properly in English.  Yesterday, I was only
> playing with data connections, and it appears that the data connection
> dialogs are mostly in Spanish.  For instance:
> Jason
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of
> *Kenneth, GEOGRAF A/S
> *Sent:* Thursday, April 10, 2008 23:55
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] ODBC problems....MGOS 2.0
> It picks up the locale from your machine.
> In the "About" dialog, you can see what the OS considers your locale.
> You should be able to select English in the initial dialog.
> I would like to find the cause for this problem, as that would be
> quite annoying for most users.
> What locale does the OS report?
> Jason Birch skrev:
> OK, so when I build MapStudioOS, most of the UI is in Spanish.
> I don't really care (pretty easy to figure out) but is there an easy
> way for me to set this?
> I'm using VS2005 by the way; seems to work fine.
> Jason
> <mailto:mapguide-users-bounces at lists.osgeo.org>
> *Sent:* Thursday, April 10, 2008 13:17
> I'm hoping it will be complete within the next week, but it's not a
> promise :)
> Andrew DeMerchant skrev:
> I don't have access to that - so I'll wait. How long till you release
> that? I know that's a tough question, but are we talking days, weeks
> or months?
> Andrew
> Kenneth, GEOGRAF A/S wrote:
> I have added the column stuff to MapStudio OS, but I have not yet
> built a new release.
> If you have access to a Visual Studio 2003 (or newer) it should be no
> problem to build one yourself.
> I am currently building an browser for unmanged resources, and I will
> release it after that.
> Ah! I had to change the MG Server service to run on the correct
> account.....though, I DID (prior to that) try (and fail) to enter the
> correct credentials right in the provider settings. anyway, that did
> it.....now on to the next problem:
> How the heck am I supposed to actually _make_ a new ODBC connection??
> In Autodesk Studio, I can at least now see my tables, and select which
> fields to use as the geometry fields (not so in MapStudioOS) - but
> when I try to save it, I get the following:
> I'd do it in MapStudioOS, but there doesn't seem to be a place to pick
> my x and y columns...And we all know that WebStudio's not so useful
> for this either....This "upgrade" to 2.0 sure is starting to feel like
> a bad idea.
> Andrew
> Dave Wilson wrote:
> The database connections are compatible and should work. Reasons why
> they might not work:
> When using connection strings the ODBC driver name is different
> between the machines or does not match the string. The DSN names are
> not the same or do not exist.
> Are the databases local to the server? If not did you change your MG
> server process to use an account with network access?
> Regards,
> Dave
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Andrew
> DeMerchant
> *Sent:* Thursday, April 10, 2008 8:44 AM
> *Subject:* [mapguide-users] ODBC problems....MGOS 2.0
> I'm trying to start to migrate to MGOS 2.0 (from 1.0.2)....I've got a
> test machine running MGOS 2.0 right now, and am testing out just
> moving my packages from my production server to my test server. Not
> surprisingly, any dataconnections I had set up on my production server
> stop working on my dev server - I assume because they were made using
> FDO 3.1, while MGOS 2 uses FDO 3.2 (it'd be awfully nice if the FDO
> people would make things backwards compatible). Anyway, I fully
> expected those to break (along with my Raster layers).
> I've hit a wall in trying to get them (my ODBC datasources) set up
> again. I've tried in Autodesk Studio, I've tried in MapStudioOS -
> neither are working. They both give me an error that is the same - "An
> exception occurred in FDO component. RDBMS: No current open
> database."....I've tried custom connection strings and DSN (which is
> my preferred method). Same result for both. I did successfully connect
> to an SQL server I have onsite, but that's not where my data is. That
> suggests to me the the problem may be with my database format - which
> is Jet (MS Access). What the solution here? If all else fails, is it
> an option for me to install FDO3.1 with MGOS2?
> Andrew
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
Skipped content of type multipart/related
