[mapguide-users] Not Implemented for MgSelection.GenerateFilter
Darrin Maidlow
dmaidlow at landorgis.com
Mon Apr 14 17:24:08 EDT 2008
Hi Steve,
Thanks for the suggestion and quick reply. I had tried MgSelection
initially, and changed it over to MgSelectionBase in my trying of things. I
just set it back and am still receiving the Not Implemented error.
One other thing I noticed that may or may not be relevant is they if I right
click and quick watch on the mgselection object, the properties are not
visible in the IDE.
Below is the XML from my selection in case it is relevant.
<FeatureSet size="1">
<Layer id="4631e36a-0000-1000-8004-0011d8b31fa4">
<Classid="Default:V_FV_BLDG_DOCUMENT">
<ID>VHlwaWNhbCBIaWdoIFJpc2UgT2ZmaWNlAJkAAAAJAAAABQAAADM2MCBDYW1lcmEACAAAADM2
MCBDYW1lcmEAbW92AAEAAAACAAAAT2ZmaWNlIC0gTGFyZ2UgMzYwANcHCAENAAAAAAAAAQAAAA==
</ID>
</Class>
</Layer>
</FeatureSet>"
Thanks again
darrin
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Steve Dang
Sent: Monday, April 14, 2008 2:47 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Not Implemented for MgSelection.GenerateFilter
Try to use MgSelection instead of MgSelectionBase (e.g. Dim currentSel As
New MgSelection(oMap))
Steve.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Darrin Maidlow
Sent: Monday, April 14, 2008 1:28 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Not Implemented for MgSelection.GenerateFilter
I'm stuck trying to work with a selection generated from the dwf viewer.
I've been working with the sample in the developers guide but ported over to
vb.net. I'm running MGE 2008.
Basically I go through the motions, create new selection based on the passed
selectionXML and everything is cool until I get to the
MgSelection.GenerateFilter call. When I pass the layer object, and the
session ID I get an MgNotImplemented error.
I've attached a text file with a bit o' code. Any suggestions would be
greatly appreciated. I'm sure I've missed something little or done
something silly.
Thanks
darrin
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080414/cccd3609/attachment.html
