[mapguide-users] Publish WMS without MapGuide Studio?
Kenneth, GEOGRAF A/S ks at geograf.dk
Tue Apr 15 07:22:32 EDT 2008
AFAIK there is no documentation for it.
I think you have to look at ResourceDocumentHeader-1.0.0.xsd.
You can read/write the document header by using the MapAgent HTTP interface:
http://localhost/mapguide/mapagent/index.html
The GetResourceHeader will give you the header information, and you can
post it back with SetResource.
A sample of such a file from my system looks like this:
<?xml version="1.0" encoding="utf-8"?>
<ResourceDocumentHeader xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="ResourceDocumentHeader-1.0.0.xsd">
  <Security xsi:noNamespaceSchemaLocation="ResourceSecurity-1.0.0.xsd">
    <Inherited>true</Inherited>
  </Security>
  <Metadata>
    <Simple>
      <Property xsi:noNamespaceSchemaLocation="Property-1.0.0.xsd">
        <Name>_Title</Name>
        <Value>tit</Value>
      </Property>
        <Name>_ExtendedMetadata</Name>
        <Value>met</Value>
      </Property>
        <Name>_Keywords</Name>
        <Value>key</Value>
      </Property>
        <Name>_Queryable</Name>
        <Value>1</Value>
      </Property>
        <Name>_Bounds</Name>
        <Value>bon</Value>
      </Property>
        <Name>_IsPublished</Name>
        <Value>1</Value>
      </Property>
        <Name>_OtherSRS</Name>
        <Value>ses</Value>
      </Property>
        <Name>_Abstract</Name>
        <Value>abs</Value>
      </Property>
        <Name>_Opaque</Name>
        <Value>1</Value>
      </Property>
    </Simple>
  </Metadata>
</ResourceDocumentHeader>
Regards, Kenneth, GEOGRAF A/S
John Pulles skrev:
> Kenneth, GEOGRAF A/S schreef:
>> Yes, but difficult.
>> You have to set up some Xml by hand, and push it into the server.
>> I'm have not yet done this, so I am not entirely sure hwo to do it.
> Would you know where to find an example about this xml format, or
> where to find documentation? I don't have MapGuide Studio installed.
> Regards,
> John
>> shane buscher skrev:
>>> Is it possible to publish a WMS without purchasing MG Studio?  If
>>> so, how?
>>> Thanx in advance,
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
