[mapguide-users] MgOs V2.0 memory problems
Marius_360 marius at openspatial.co.za
Wed Apr 16 01:28:52 EDT 2008
I am using the full client, I will start using the instant client to see if
it works. But the interresting thing I saw now is that this problem only
occurs when I open my map through the Web Layout preview in Studio, when I
open the website that our developers created, it works perfectly!
Thanks for the help so far!
zspitzer wrote:
> which version are you using, instant client or full client?
> make sure with the instant client that the dll's are in the fdo
> directory, not a subdir of the fdo directory
> i have seen this problem before, i was recommend to use the instant
> client version with the exact version of the sl-king site
> On Tue, Apr 15, 2008 at 11:32 PM, Marius_360 <marius at openspatial.co.za>
> wrote:
>>  Using SDF's are unfortunatly not an option. The tolerance I am using is
>> 10cm
>>  (I am asuming you are talking about the tolerance in the metadata
>> table). At
>>  the moment there are at most 4 layers on at any one time, but I have
>> tried
>>  with only one layer, it then just takes longer for the memory to be used
>> up,
>>  but eventually the result is the same.
>>  The overall performance is fine till all the memory is used up. Is this
>>  perhaps not some sort of memory leak?
>>  zspitzer wrote:
>>  > there is a big overhead in using oracle, basically FDO involves
>>  > getting a WKT type
>>  > datatype out of oracle spatial datatype which is quite an overhead.
>>  > if you try using the oracle WKT functions via sql you will see a
>>  > similar conversion overhead
>>  > Your better off moving static data into SDF's to avoid that conversion
>>  > every time you
>>  > make a map  or at least make use of tiled maps for base oracle layers.
>>  > That said, you shouldn't be having the problems your seeing...
>>  > generalising your data might help... what's the tolerance of your
>> data?
>>  > depending on what your doingthere's not much point in making maps at
>>  > street level with
>>  > data that is down to say 5mm if you get my drift, when 1m would
>> suffice
>>  > how does it perform with just a single oracle layer? can you isolate
>>  > the problem down a bit?
>>  > z
>>  > On Tue, Apr 15, 2008 at 9:04 PM, Marius_360 <marius at openspatial.co.za>
>>  > wrote:
>>  >>  Hi All
>>  >>  My map runs on Windows Server 2003, Oracle 10Gr2, Mapguide
>> Opensource 2
>>  >> and
>>  >>  the latest King providers but I am encountering problems when
>> zooming in
>>  >> a
>>  >>  few times. After zooming in 2-3 times I get no more response from
>> the
>>  >> map
>>  >>  i.e a blank screen and no more loading. When I have a look at the
>> server
>>  >>  memory usage, the mapguide service is using 75% of the total
>> available
>>  >> ram
>>  >>  (1.5gb out of 2gb).When I close the map as well as Studio the memory
>> is
>>  >> not
>>  >>  freed up. After restarting the server and opening the map again the
>>  >> memory
>>  >>  used steadily climbs up to 1.5gb again. The oracle spatial layers I
>> am
>>  >> using
>>  >>  so far are not even close to that size, so I don't know what the
>> problem
>>  >> is.
>>  >>  Does anyone have an Idea what is happening?
>>  >>  Regards,
>>  >>  Marius
>>  >>  View this message in context:
>> http://www.nabble.com/MgOs-V2.0-memory-problems-tp16699534s16610p16699534.html
>>  >>  Sent from the MapGuide Users mailing list archive at Nabble.com.
>>  >>  _______________________________________________
>>  >>  mapguide-users mailing list
>>  >>  mapguide-users at lists.osgeo.org
>>  >>  http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>  > Zac Spitzer -
>>  > http://zacster.blogspot.com (My Blog)
>>  > +61 405 847 168
>> http://www.nabble.com/MgOs-V2.0-memory-problems-tp16699534s16610p16700574.html
> Zac Spitzer -
> +61 405 847 168
View this message in context: http://www.nabble.com/MgOs-V2.0-memory-problems-tp16699534s16610p16716736.html
