[mapguide-users] Problem map Sheboygan
Jérémie Formica
jeremie.formica at gmail.com
Thu Apr 17 09:09:33 EDT 2008
What is it "the test case"?? How make this test?
Thank's you very much for your help
2008/4/17, Zac Spitzer <zac.spitzer at gmail.com>:
> did you download the test case data from subversion and run the test
> cases?
> On Thu, Apr 17, 2008 at 10:43 PM, Jérémie Formica
> <jeremie.formica at gmail.com> wrote:
> > I have install firebug and they are any error.
> > When I click on the map I can see the different action who are make (
> > GET(.....)) But they are nothing...
> > 2008/4/17, Jackie C. Ng <jumpinjackie at gmail.com>:
> > > Try installing firebug. See if there are any errors thrown.
> > > - Jackie
> > > Jérémie Formica wrote:
> > > > No I have Firefox 1.5 and I have try with IE 7. But the the same
> > result...
> > > > Please Help me :(
> > > > 2008/4/17, Jackie C Ng <jumpinjackie at gmail.com>:
> > > >> Are you using the latest betas of Firefox 3 by any chance?
> > > >> - Jackie
> > > >> > hello,
> > > >> > I have install mapguideOS 2 on centOs5. When I go on
> http://localhost:8008/mapguide/phpviewersample/ajaxviewersample.php,
> > I
> > > >> see
> > > >> > the application but not the map. I have load sheboygan.mgp.
> > > >> > I join a screen shot to understand my problem.
> > > >> > Thanks you.
> > > >> > _______________________________________________
> > > >> > mapguide-users mailing list
> > > >> > mapguide-users at lists.osgeo.org
> > > >> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> > > >> http://themapguyde.blogspot.com
> > > >> http://www.linkedin.com/in/jackieng
> > > >> View this message in context:
> http://www.nabble.com/Problem-map-Sheboygan-tp16718708s16610p16736635.html
> > > >> Sent from the MapGuide Users mailing list archive at Nabble.com.
> http://www.nabble.com/Problem-map-Sheboygan-tp16718708s16610p16743938.html
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080417/89b9d865/attachment.html
