[mapguide-users] .NET Fusion
Jackie C. Ng
jumpinjackie at gmail.com
Thu Apr 17 12:44:23 EDT 2008
The reason I ask is that fusion does map names differently from the normal
ajax viewer. I think it's of the form [MapName][some long guid] instead of
[MapName]
- Jackie
Berdel, Brian wrote:
> Hi Jackie,
> I am actually passing it via a session variable from another Sub. It is
> the correct value. And like I said the code does work in the regular
> Ajax viewer.
> String smgMap = (Session["smgMap"]).ToString();
> Brian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie C Ng
> Sent: Wednesday, April 16, 2008 8:45 PM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] .NET Fusion
> Where are you getting that value of the variable smgMap ?
> - Jackie
>> If I try to access a map via .net fusion I always get this
> error...Code
>> works fine in regular viewer. I have heard conflicting reports of
>> Fusion and .NET can someone please clarify?
>> MgUserInformation userInfo = new MgUserInformation(mgSessionId);
>> MgSiteConnection siteConnection = new MgSiteConnection();
>> siteConnection.Open(userInfo);
>> MgResourceService resourceService =
>> siteConnection.CreateService(MgServiceType.ResourceService) as
>> MgResourceService;
>> MgMap map = new MgMap();
>> map.Open(resourceService, smgMap);
>> Resource was not found:
> Session:ba7530b4-ffff-ffff-800a-00142260e7d1_en_7F0000010AFC0AFB0AFA//So
>> leburyTwp.Map
>> Description: An unhandled exception occurred during the execution of
> the
>> current web request. Please review the stack trace for more
> information
>> about the error and where it originated in the code.
>> Exception Details: OSGeo.MapGuide.MgResourceNotFoundException:
> Resource
>> was not found:
>> leburyTwp.Map
>> Source Error:
>> Line 28: MgResourceService resourceService =
>> MgResourceService;
>> Line 29: MgMap map = new MgMap();
>> Line 30: map.Open(resourceService, smgMap);
>> Brian Berdel
>> McMahon Associates, Inc.
>> p: 215.283.9444
>> www.mcmtrans.com
>> Brian Berdel
>> Applications Development Manager
>> 425 Commerce Drive, Suite 200
>> Fort Washington, Pennsylvania 19034
>> p: 215.283.9444
>> f: 215.283.9858
>> brian.berdel at mcmtrans.com
>> <http://www.mcmtrans.com>
>> New England | Mid-Atlantic | Florida
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/.NET-Fusion-tp16722611s16610p16736574.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/.NET-Fusion-tp16722611s16610p16746611.html
