[mapguide-users] Can you execute an FDO Spatial filter on x,y
data in oledb datasource?
nclayton
nclayton at gmail.com
Thu Apr 17 13:54:24 EDT 2008
Nick Adams wrote:
> What I would like to do is to apply this same polygon to a database of
> points where rather than being a geometry type they are stored as x,y
> pairs in separate columns.
In your connection to the data in MapGuide Studio, you can define X,Y
columns as a geometry type for tables.
Under the Connection String section, there is a section labeled "Define
geometry properties to create spatial feature classes (optional)"
Click the "Show tables" button to display your databases tables. Put a check
in the box for the "Geometry?" column, then select your X,Y and possibly Z
columns. Then specify the coordinate system to apply.
Hope this helps.
View this message in context: http://www.nabble.com/Can-you-execute-an-FDO-Spatial-filter-on-x%2Cy-data-in-oledb-datasource--tp16746846s16610p16749182.html
