[mapguide-users] .NET Fusion
Jason Birch
Jason.Birch at nanaimo.ca
Thu Apr 17 16:09:05 EDT 2008
Even when MapGuide is installed as a .Net application under IIS, the PHP
extensions are also installed (I believe to support the MapAdmin), so
you can run both .Net MapGuide and PHP MapGuide on the same server. In
this configuration, Fusion works using the PHP extensions, and you can
also use the .Net extension.
You're limited to using a single "viewer" virtual directory (or setting
up both the PHP viewer directory and the ASPX viewer directly
explicitly), but as long as you're using Fusion as your viewer this
isn't important.
Jason
-----Original Message-----
Subject: Re: [mapguide-users] .NET Fusion
Well perhaps I am misunderstanding something here then. It is possible
that the MGOS side of things are running in a .NET environment, but
unless you have converted the PHP scripts in fusion/MapGuide/php to
.NET, I don't see how Fusion can run at all. At a bare minimum you
would have to convert LoadMap.php, CreateSession.php and their includes.
In any case, the the map name is set as follows (in the PHP version of
LoadMap):
$mapName = uniqid($mapTitle);
$mapStateId = new MgResourceIdentifier("Session:" . $sessionID .
"//" . $mapName . "." . MgResourceType::Map);
where $mapTitle is the map name as set in MGOS and uniqid() returns a
unique ID based on the current time.
