[mapguide-users] Precision when selecting polygons
Krunoslav a_krunoslav at gmx.net
Fri Apr 18 01:26:08 EDT 2008
Krunoslav wrote:
> Traian Stanev wrote:
>> You need to have the user name and password in the connection string, and
>> not in the separate username and password fields that you see in Studio.
>> So something like:
>> MYSQL:database,username=myself,password=secret,host=mycomputer,port=666
>> Is this what you are doing?
> Same thing:
> MYSQL:database,username=root,password=65lkp12,host=localhost,port=3306
> User name  and password fields empty, and same error again:
> System.FormatException: String was not recognized as a valid Boolean.
>    at System.Boolean.Parse(String value)
>    at
> Autodesk.MapGuide.Studio.Site.Comm.RequestManager.TestConnection(String
> resourceId, String provider, String connectionString)
>    at Autodesk.MapGuide.Studio.Site.FeatureSourceInfo.TestConnection()
>    at
> Autodesk.MapGuide.Studio.UI.FeatureSourceEditors.TestConnectionControl.buttonTestConnection_Click(Object
> sender, EventArgs e)
> Setup: MgOS2.0, Mysql 5.0.37
> As stated before, FDO provider for MySQL works fine with this setup.
WELL, I finally solved the error! There's obviously something wrong with
Mapguide studio. I can connect as you mentioned above without problems with
Map Studio OpenSource.
Thanks again.
View this message in context: http://www.nabble.com/Precision-when-selecting-polygons-tp16718926s16610p16760358.html
