[mapguide-users] FDO - CLNT_8 error
Marc Pfister
mpfister at enplan.com
Mon Apr 21 18:08:39 EDT 2008
Some new strangeness -
I have MGOS 1.2 installed on FC6 and previously it was working just
fine.
Now for some reason I'm getting:
1863|2630790032) An exception occurred in FDO component.
CLNT_8_UNABLE_TO_LOAD_LIBRARY
Exception occurred in method MgFdoConnectionManager.Open at line 259 in
file FdoConnectionManager.cpp
This seems to mean FDO can't access one of the providers.
If I snoop around the FDO libs with ldd, it says the libFDO-3.2.2 it
can't find the xalan and xerces libraries. Which is strange, because
they are in that same folder. If I export the FDO lib folder to
LD_LIBRARY_PATH then ldd is able to find the libraries to link to, but I
still get the error.
I have tried both a clean and a subsequent install of both the FDO and
ThirdParty scripts with no change in the error message.
Any ideas? Do I need to reinstall the Mapguide side too?
n
Marc Pfister
Geospatial Data Manager
ENPLAN
530/221-0440 x108
530/221-6963 Fax
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080421/bc6fcf56/attachment.html
