[mapguide-users] How to make features unique in markup layer?
Jackie C. Ng
jumpinjackie at gmail.com
Fri Apr 25 01:01:56 EDT 2008
What does the table definition look like in your database? Can you give a
sample of some of the rows from this database table?
- Jackie
Tanja Suikkanen wrote:
> Our markup layers are only in Library repository.
> In the database there is information about one markup feature per Id.
> I don't know if you meant this, but here it is:
> <?xml version="1.0" encoding="UTF-8"?>
> <FeatureInformation>
> <FeatureSet xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:noNamespaceSchemaLocation="FeatureSet-1
> .0.0.xsd"> <Layer id="6a4667be-0000-1000-8007-001a4b7564d4"> <Class
> id="MarkupSchema:Markup"> <ID
>>AgAAAA==</ID> </Class> </Layer></FeatureSet><Tooltip />
> <Hyperlink />
> <Property name="ID" value="2" />
> </FeatureInformation>
> All markup layers are created with the phpGenericTasks sample code.
> Now we thought if we put the layer definition (Library://somepath/.) and
> the
> propertys id value (2) in an array or something.
> Then we get a value pair which we can compare to ids in the database.
> If you have a better idea, please tell!
> Tanja
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/How-to-make-features-unique-in-markup-layer--tp16848626p16890697.html
