[mapguide-users] OnSelectionChanged in AJAX viewer?
Tanja Suikkanen
tanja.suikkanen at dimenteq.fi
Mon Apr 28 02:47:02 EDT 2008
I visited the link you sent Jackie and used it in my code but still my app
doesn't work...
I send here a little snippet of my code:
var map = parent.parent.mapFrame;
var origOnSelectionChanged = null;
function MySelectionHandler()
origOnSelectionChanged();
var selCount = map.GetSelectedCount();
if(selCount > 0)
My function() {}
window.onload = function() {
var timer;
var watch = function() {
try {
if(map.mapInit) {
clearInterval(timer);
origOnSelectionChanged = map.OnSelectionChanged;
map.OnSelectionChanged = MySelectionHandler;
catch(e) {
timer = setInterval(watch, 200);
I tested the code and it never goes to the loop if(map.mapInit) unless I
click my button first.
What is wrong here??
Tanja
