[mapguide-users] Out of Memory error problem
Maksim Sestic
max at geoinova.com
Mon Apr 28 09:08:19 EDT 2008
Happens to me more more than often. I have couple of tiled base layers
(orthophoto, scanned maps, relief maps, etc.) set to fixed list of integer
scales. There's a problem with "empty" tile rendering, where random tiles
simply get skipped (don't get rendered at all) and get cached that way. But
that's not causing "Out of Memory error problem".
What I did notice is that if I include ODBC-based (unmanaged) dynamic layers
it crashes twice or more frequently than if there're only FDO-based
(managed) dynamic layers. Each and every data source (both managed and
unmanaged) runs on SQL Server 2000/2005. Crashed MG server process reports
no error whatsoever.
Regards,
Maksim Sestic
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of nclayton
Sent: Monday, April 28, 2008 14:48
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Out of Memory error problem
Hi all,
I have been having problems with MGOS 2.0 crashing on me to the point that i
was using a script to restart the service every 30 minutes.
I resolved part of the problem by changing how one of my layers was
rendered.
But, after running without a restart for about 2 days I got the following
errors:
<2008-04-25T11:32:56> Anonymous
Error: An exception occurred in FDO component.
'FdoFgfLinearRing::Reset': Cannot execute function due to invalid
value for the input parameter(s) 'positions'.
StackTrace:
- MgRenderingServiceHandler.ProcessOperation line 83 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\
services\rendering\RenderingServiceHandler.cpp
- MgOpQueryFeatures.Execute line 125 file
services\rendering\OpQueryFeatures.cpp
- MgServerRenderingService.QueryFeatures line 647 file
services\rendering\ServerRenderingService.cpp
- MgServerRenderingService.RenderForSelection line 1252 file
- MgServerSelectFeatures.SelectFeatures line 249 file
services\feature\ServerSelectFeatures.cpp
'FdoFgfLinearRing::Reset': Cannot execute function due to invalid value for
<2008-04-25T11:57:23> Anonymous
Error: Failed to stylize layer: aerial
Out of memory.
bad allocation
StackTrace:
- MgMappingUtil.StylizeLayers line 776 file
services\mapping\MappingUtil.cpp
Out of memory.
bad allocation
<2008-04-25T12:21:39> Anonymous
Error: Out of memory.
bad allocation
StackTrace:
- MgOpRenderDynamicOverlay.Execute line 109 file
services\rendering\OpRenderDynamicOverlay.cpp
- MgServerRenderingService.RenderDynamicOverlay line 305 file
Out of memory.
bad allocation
Thank you for any help that can be provided.
View this message in context:
http://www.nabble.com/Out-of-Memory-error-problem-tp16938026p16938026.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
__________ NOD32 3059 (20080428) Information __________
This message was checked by NOD32 antivirus system.
http://www.eset.com
