[mapguide-users] Out of Memory error problem
nclayton nclayton at gmail.com
Mon Apr 28 12:19:20 EDT 2008
I'm watching my mgserver.exe in task manager, and it is currently up to
830MB+.
My OS is Windows 2003 Standard and I am using MGOS 2.0
I am hosting multiple maps. Currently there are 4 but once I get these
wrinkles ironed out there will be 20+.
Are there steps that I can perform to reduce the amount of memory being
used? Such as programatically close connections or something? Right now the
service is set to restart every 4 hours...which should remove the used
memory, but at the price of losing user sessions which is what I'm trying to
avoid.
nclayton wrote:
> Hi all,
> I have been having problems with MGOS 2.0 crashing on me to the point that
> i was using a script to restart the service every 30 minutes.
> I resolved part of the problem by changing how one of my layers was
> rendered.
> But, after running without a restart for about 2 days I got the following
> errors:
> <2008-04-25T11:32:56> 			Anonymous
>  Error: An exception occurred in FDO component.
>         'FdoFgfLinearRing::Reset': Cannot execute function due to invalid
> value for the input parameter(s) 'positions'.
>  StackTrace:
>   - MgRenderingServiceHandler.ProcessOperation line 83 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
>   - MgOpQueryFeatures.Execute line 125 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
>   - MgServerRenderingService.QueryFeatures line 647 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\rendering\ServerRenderingService.cpp
>   - MgServerRenderingService.RenderForSelection line 1252 file
>   - MgServerSelectFeatures.SelectFeatures line 249 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\ServerSelectFeatures.cpp
> 'FdoFgfLinearRing::Reset': Cannot execute function due to invalid value
> <2008-04-25T11:57:23> 			Anonymous
>  Error: Failed to stylize layer: aerial
>         Out of memory.
>         bad allocation
>  StackTrace:
>   - MgMappingUtil.StylizeLayers line 776 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\mapping\MappingUtil.cpp
> Out of memory.
> bad allocation
> <2008-04-25T12:21:39> 			Anonymous
>  Error: Out of memory.
>         bad allocation
>  StackTrace:
>   - MgOpRenderDynamicOverlay.Execute line 109 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\rendering\OpRenderDynamicOverlay.cpp
>   - MgServerRenderingService.RenderDynamicOverlay line 305 file
> Out of memory.
> bad allocation
> Thank you for any help that can be provided.
View this message in context: http://www.nabble.com/Out-of-Memory-error-problem-tp16938026p16942501.html
