[mapguide-users] Add a new point to layer ( digitizing )
Rahul sharma rahulonline22 at yahoo.com
Tue Apr 29 20:18:22 EDT 2008
Hi
I am using Map Guide Open Source and map guide studio 2008 . for my project
i am trying to digitize a point to the map. i have created a javascript
which pass the coordinates and on formsubmit invoke the php. The code should
creates a layer and add it back to the map.
But i have problem displaying the point and its not doing anything any
suggession or help wil be greatful
the code is as under
<?php
require_once('../common/common.php');
require_once($webExtensionsDirectory .
'www/mapviewerphp/layerdefinitionfactory.php');
require_once('layer_functions.php');
  $args = ($_SERVER['REQUEST_METHOD'] == "POST")?$_POST: $_GET;
  $sessionId = $args['SESSION'];
  $mapName = $args['MAPNAME'];
// coordiantes of cliked point of map (user can add new point to map)
// it comes form javascript ,
$x=$_GET['X'];
$y=$_GET['Y'];
try
    // Initialize
    MgInitializeWebTier($webconfigFilePath);
    $sessionId = ($_SERVER['REQUEST_METHOD'] == "POST")?$_POST['SESSION']:
$_GET['SESSION'];
    $userInfo = new MgUserInformation($sessionId);
    $siteConnection = new MgSiteConnection();
    $siteConnection->Open($userInfo);
    $resourceService =
$siteConnection->CreateService(MgServiceType::ResourceService);
    $featureService =
$siteConnection->CreateService(MgServiceType::FeatureService);
    // Open the map
    $map = new MgMap();
    $map->Open($resourceService, $mapName);
    // Create a feature source with point data.
    // (The Sheboygan sample data does not contain such data,
    // so we'll create it.)
        // Create a feature class definition for the new feature source
        $classDefinition = new MgClassDefinition();
        $classDefinition->SetName("Points");
        $classDefinition->SetDescription("Feature class with point data.");
        $classDefinition->SetDefaultGeometryPropertyName("GEOM");
        // Create an identify property
        $identityProperty = new MgDataPropertyDefinition("KEY");
        $identityProperty->SetDataType(MgPropertyType::Int32);
        $identityProperty->SetAutoGeneration(true);
        $identityProperty->SetReadOnly(true);
        // Add the identity property to the class definition
        $classDefinition->GetIdentityProperties()->Add($identityProperty);
        $classDefinition->GetProperties()->Add($identityProperty);
        // Create a name property
        $nameProperty = new MgDataPropertyDefinition("NAME");
        $nameProperty->SetDataType(MgPropertyType::String);
        // Add the name property to the class definition
        $classDefinition->GetProperties()->Add($nameProperty);
        // Create a geometry property
        $geometryProperty = new MgGeometricPropertyDefinition("GEOM");
$geometryProperty->SetGeometryTypes(MgFeatureGeometricType::Surface);
        // Add the geometry property to the class definition
        $classDefinition->GetProperties()->Add($geometryProperty);
        // Create a feature schema
        $featureSchema = new MgFeatureSchema("PointSchema", "Point schema");
        // Add the feature schema to the class definition
        $featureSchema->GetClasses()->Add($classDefinition);
        // Create the feature source
        $featureSourceName =
"Session:$sessionId//TemporaryPoints.FeatureSource";
        //$featureSourceName =
"Library://EelGrass/DevGuide/Data/points.FeatureSource";
        $resourceIdentifier = new MgResourceIdentifier($featureSourceName);
        $wkt = $map->GetMapSRS();
        //$wkt =
"LOCALCS[\"*XY-MT*\",LOCAL_DATUM[\"*X-Y*\",10000],UNIT[\"Meter\",
1],AXIS[\"X\",EAST],AXIS[\"Y\",NORTH]]";
        $sdfParams = new MgCreateSdfParams("ArbitraryXY", $wkt,
$featureSchema);
    $featureService->CreateFeatureSource($resourceIdentifier, $sdfParams);
        // We need to add some data to the sdf before using it.  The spatial
context
        // reader must have an extent.
        $batchPropertyCollection = new MgBatchPropertyCollection();
        $wktReaderWriter = new MgWktReaderWriter();
        $agfReaderWriter = new MgAgfReaderWriter();
        $geometryFactory = new MgGeometryFactory();
    // Create some point and display them using Make Point function
        $propertyCollection = MakePoint("PointA", $x,$y);
        $batchPropertyCollection->Add($propertyCollection);
        unset($propertyCollection);
        $propertyCollection = MakePoint("Point B", 237923.91,5842975.50);
        // Add the batch property collection to the feature source
        $cmd = new MgInsertFeatures("Points", $batchPropertyCollection);
        $featureCommandCollection = new MgFeatureCommandCollection();
        $featureCommandCollection->Add($cmd);
        // Execute the "add" commands
        $featureService->UpdateFeatures($resourceIdentifier,
$featureCommandCollection, false);
    // Create a new layer
    $factory = new LayerDefinitionFactory();
    // Create a mark symbol
    $resourceId = 'Library://EelGrass/Symbols/BasicSymbols.SymbolLibrary';
    $symbolName = 'Point';
    $width = '24';  // unit = points
    $height = '24'; // unit = points
    $color = 'FFFF0000';
    $markSymbol = $factory->CreateMarkSymbol($resourceId, $symbolName,
$width, $height, $color);
    // Create a text symbol
    $text = "ID";
    $fontHeight="12";
    $foregroundColor = 'FF000000';
    $textSymbol = $factory->CreateTextSymbol($text, $fontHeight,
$foregroundColor);
    // Create a point rule.
    $legendLabel = 'trees';
    $filter = '';
    $pointRule = $factory->CreatePointRule($legendLabel,$filter,
$textSymbol, $markSymbol);
    // Create a point type style.
    $pointTypeStyle = $factory->
      CreatepointTypeStyle($pointRule);
    // Create a scale range.
    $minScale = '0';
    $maxScale = '1000000000000';
    $pointScaleRange = $factory->CreateScaleRange($minScale, $maxScale,
$pointTypeStyle);
         // Create the layer definiton.
    $featureName = 'PointSchema:Points';
    $geometry = 'GEOM';
    $layerDefinition =
$factory->CreateLayerDefinition($featureSourceName,$featureName, $geometry,
$pointScaleRange);
   // Add layer permanently to the map using XML writer
        $byteSource = new MgByteSource($layerDefinition,
strlen($layerDefinition));
        $byteSource->SetMimeType(MgMimeType::Xml);
        $resourceIden = new
MgResourceIdentifier("Library://Project/Data/Points.FeatureSource");
        $resourceService->SetResource($resourceIden,
$byteSource->GetReader(), null);
        // Add the layer to the map
    $newLayer = add_layer_definition_to_map($layerDefinition, "Points",
"Points of Interest", $sessionId, $resourceService, $map);
    add_layer_to_group($newLayer, "Analysis", "Analysis", $map);
    // Turn on the visibility of this layer.
    // (If the layer does not already exist in the map, it will be visible
by default when it is added.
    // But if the user has already run this script, he or she may have set
the layer to be invisible.)
    $layerCollection = $map->GetLayers();
    if ($layerCollection->Contains("Points"))
        $pointsLayer =$layerCollection->GetItem("Points");
        $pointsLayer->SetVisible(true);
    //  Save the map back to the session repository
    $sessionIdName = "Session:$sessionId//$mapName.Map";
    $sessionResourceID = new MgResourceIdentifier($sessionIdName);
    $sessionResourceID->Validate();
    $map->Save($resourceService, $sessionResourceID);
catch (MgException $e)
        echo "<script language=\"javascript\" type=\"text/javascript\"> \n";
        echo "    alert(\" " . $e->GetMessage() . " \"); \n";
        echo "</script> \n";
function MakePoint($name, $x, $y)
        $propertyCollection = new MgPropertyCollection();
        $nameProperty = new MgStringProperty("NAME", $name);
        $propertyCollection->Add($nameProperty);
        $geometry = $wktReaderWriter->Read("POINT XY ($x $y)");
        $geometryByteReader = $agfReaderWriter->Write($geometry);
        $geometryProperty = new MgGeometryProperty("GEOM",
$geometryByteReader);
        $propertyCollection->Add($geometryProperty);
        return $propertyCollection;
</body>
</html>
View this message in context: http://www.nabble.com/Add-a-new-point-to-layer-%28-digitizing-%29-tp16973289p16973289.html
