[mapguide-users] MG2.0 install with other web applications
Jason Birch Jason.Birch at nanaimo.ca
Wed Apr 30 13:50:58 EDT 2008
Yes, I've seen this too.  You can't run 1.1 and 2.0 apps in the same
application pool.
Technically, you only need a single application pool for each .Net
version, but really should probably create a separate pool just for
MapGuide.  This can be shared across all of the MapGuide virtual
directories if you want.
You can also run MapGuide outside of your default website.  Just export
the current mapguide virtual directory (or maybe the website) to a
config file and then re-import the mapguide virtual directory into the
new website.  Make sure to set up the alternate application pool before
doing this though.
Jason
-----Original Message-----
Subject: RE: [mapguide-users] MG2.0 install with other web applications
I believe the issue may be related to the fact that .NET 1.1 and 2.0
apps must each run in their own application pool if I remember something
I read a while back. You might have to define separate application pools
for each virtual directory.
Subject: [mapguide-users] MG2.0 install with other web applications
I'm looking to find out how to install MapGuide 2.0 server along with
other
web applications that are installed in the "Default Website" location in
the
IIS manager?  We've run into a challenge with the server not running
correctly along side web applications that use .NET1.1.  The problem
exists
after everything is installed.  I can log into the admin page and the
web
studio page, but when I try to connect to the server via MapGuide Studio
2009 beta or AutoCAD Map, I get a connection error.  When I change the
ASPNET tab to run .NET 2.0 for the mapguide server it makes all the
other
.NET 1.1 sites lock up and shows an error message in IIS of not being
able
to run both 1.1 and 2.0 applications in one location.
