[mapguide-users] MG 1.2 vs 2.0.1
Zac Spitzer
zac.spitzer at gmail.com
Mon Aug 4 05:28:31 EDT 2008
George,
Sorry to clarify my last answer, accessing the result has no effect on
the operation, but
UpdateFeatures doesn't throw an exception which means you may be
getting a MySQL error
without realising it..
The API docs could do with some fleshing out in this area
z
On Fri, Aug 1, 2008 at 11:05 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> yep...it does fail silently, which is really annoying.. it should just
> raise an exception
> On Fri, Aug 1, 2008 at 4:16 AM, George McLean <gmclean at gorge.net> wrote:
>> No I am not. Does this ignore the error message and process the update
>> somehow?
>> Zac Spitzer wrote:
>>> Are you checking the result as bellow
>>> result=featureService.UpdateFeatures(resourceID, fCommand, false);
>>> if (result.GetItem(0).GetPropertyType() eq 9)
>>> result.GetItem(0).GetValue() // Silent FDO error messages!!!!
>>> z
>>> On Fri, Aug 1, 2008 at 2:14 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>>>> can you post some code to demonstrate the problem?
>>>> On Fri, Aug 1, 2008 at 2:05 AM, George McLean <gmclean at gorge.net> wrote:
>>>>> Hello,
>>>>> I am a bit stuck in upgrading to 2.0.1 mainly due to the issues with
>>>>> adding
>>>>> data to feature sources discussed in this thread:
>>>>> http://www.nabble.com/Please-try-your-operation-later-as-the-resource-was-busy-to16392736.html#a18556960
>>>>> My immediate issue is that I have a client that would really like to us
>>>>> FF
>>>>> 3.0 with my application. I see that either I need to find a way to apply
>>>>> the
>>>>> fixes made in 2.0 for FF to 1.2 or find a way around the issues with
>>>>> updating feature data.
>>>>> I could look at the code for MG 1.2 and apply the changes made to 2.0
>>>>> with
>>>>> some guidance on where to start but I think I would rather find a fix
>>>>> for MG
>>>>> 2.0.
>>>>> Any suggestions would be appreciated.
>>>>> Thanks
>>>>> George McLean
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> Zac Spitzer -
>>>> http://zacster.blogspot.com (My Blog)
>>>> +61 405 847 168
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
