[mapguide-users] How do i load raster in MGOS 2?
jamesdudden
jamesdudden at blueyonder.co.uk
Tue Aug 5 05:07:23 EDT 2008
Thank you for your on-going help - i now have the print outs from a working
tif file and one that doesn't show up:
NOT WORKING:
Driver: GTiff/GeoTIFF
Files: C:\Program Files\FWTools2.2.1\Savills.tif
Size is 7874, 7874
Coordinate System is `'
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 7874.0)
Upper Right ( 7874.0, 0.0)
Lower Right ( 7874.0, 7874.0)
Center ( 3937.0, 3937.0)
Band 1 Block=128x128 Type=Byte, ColorInterp=Palette
NBITS=1
Color Table (RGB with 2 entries)
0: 255,255,255,255
1: 0,0,0,255
WORKING:
Files: C:\Program Files\FWTools2.2.1\Marble.tif
Size is 21600, 21600
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235630016,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (-180.000000000000000,90.000000000000000)
Pixel Size = (0.002083333333333,-0.002083333333333)
Metadata:
AREA_OR_POINT=Area
INTERLEAVE=BAND
Corner Coordinates:
Upper Left (-180.0000000, 90.0000000) (180d 0'0.00"W, 90d 0'0.00"N)
Lower Left (-180.0000000, 45.0000000) (180d 0'0.00"W, 45d 0'0.00"N)
Upper Right (-135.0000000, 90.0000000) (135d 0'0.00"W, 90d 0'0.00"N)
Lower Right (-135.0000000, 45.0000000) (135d 0'0.00"W, 45d 0'0.00"N)
Center (-157.5000000, 67.5000000) (157d30'0.00"W, 67d30'0.00"N)
Band 1 Block=21600x1 Type=Byte, ColorInterp=Red
NoData Value=20
Band 2 Block=21600x1 Type=Byte, ColorInterp=Green
NoData Value=20
Band 3 Block=21600x1 Type=Byte, ColorInterp=Blue
NoData Value=20
I can see an obvious difference in the amount of data - but i don't create
the files so what do i need to tell the person who does create them in order
to make them work?
Kind regards to all
James Dudden
View this message in context: http://www.nabble.com/How-do-i-load-raster-in-MGOS-2--tp18648843p18827267.html
