[mapguide-users] An exception occurred in DB XML component. Error: Out of memory in NsSAX2Reader parse File
Tom Chadwin tom.chadwin at nnpa.org.uk
Tue Aug 5 05:10:49 EDT 2008
Hello all
This morning, our MGOS was giving the following error:
NsSAX2Reader parse File: ..\src\dbxml\nodeStore\NsSAX2Reader.cpp Line: 346
Exception occurred in method MgResourceDefinitionManager.ValidateDocument at
line 429 in file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
MGOS2.0 (might be 2.01, not sure - how do I check?)
W2K3 SP2, IIS, PHP
Xeon 2.8GHz, 3.37 GB
System disk 50GB (30GB free) - MGOS installed on this volume
Data disk 225GB (218GB free) - MGOS repository on this volume
No other apps running on this box
I don't know how to reproduce the error - as I say, it just seemed to be
consistently displaying this morning. Stopping the MGOS service failed
(Error 1053: The service did not respond to the start or control request in
a timely fashion). A reboot of the box brought it back to life.
Has anyone seen this problem (a search of this list brings back an MGOS1.0
instance)? If so, is there a solution, or at least any idea what the cause
might be?
Thanks
Tom
View this message in context: http://www.nabble.com/An-exception-occurred-in-DB-XML-component.-Error%3A-Out-of-memory-in-NsSAX2Reader-parse-File-tp18827313p18827313.html
