[mapguide-users] fusion - default tool selected?
Mike Adair
madair at dmsolutions.ca
Thu Aug 7 13:17:48 EDT 2008
Yes if there were new options for the Extension element, these would
have to be incorporated into Studio/Maestro as a new checkbox, but that
is a possibility. In the meantime you will have to go with the init
function.
There isn't an API documentation link yet (that I know of) but that is a
task in the Trac for a future release.
Mike
Andrew DeMerchant wrote:
> hmm.....so that would involve editing the Select widget and the
> ApplicationDefinition.xml - but in my case, since I'm using Studio /
> Maestro, there IS no ApplicationDefinition.xml file to edit, is there?
> . Surely there's got to be some way to do it just from that init
> function. Is there some link that you know of to get the API?
> Andrew
> Mike Adair wrote:
>> Andrew,
>> Testing that code snippet doesn't work for me because the
>> activateWidget() method is only defined on the MapWidget.
>> A more generic solution for this would be to add an
>> <Activated>true</Activated> element for widgets in the
>> ApplicationDefinition file. Currently there is a <Disabled> property
>> for widgets to disable widgets on startup, this would be something
>> similar.
>> Mike
>>> Would there be a way to do this more generically (ie without having
>>> to hard-code the main name)? Like, why does this work:
>>> var mapWidget = Fusion.getWidgetById('Pan');
>>> mapWidget.activateWidget(Fusion.getWidgetsByType('Pan')[0]);
>>> The link to the fusion api on the trac site doesn't exist - so I
>>> don't really see a place to check this stuff....
>>> Andrew
>>> Mike Adair wrote:
>>>> In your Fusion init method (i.e. a function registered to the
>>>> FUSION_INITIALIZED event), you can activate a widget like so:
>>>> var mapWidget = Fusion.getMapById('mainMap');
>>>> //enable pan widget
>>>> getWidgetsByType returns an array of widgets so the [0] in the
>>>> above statement just selects the first instance of the Pan widget.
>>>> Mike
>>>>> Is there a way to make the Select tool selected by default in
>>>>> fusion? What I mean is, if I load a Fusion map there is no tool
>>>>> selected. So the user can click and click all they want, but
>>>>> nothing will ever happen until they pick the Select tool (or some
>>>>> other tool). In AJAX and DWF, the Select tool is selected by
>>>>> default - so as soon as the map loads, you can start clicking on
>>>>> the map to see stuff....Is there an easy way to do that in Fusion?
>>>>> Is it a matter of editing the templates somehow?
>>>>> Andrew
>>>>> *Andrew DeMerchant*
>>>>> *Computer Technologist*
>>>>> ph.1-877-2GEMTEC x.163
>>>>> fax 506-453-9470
>>>>> /GEMTEC Limited <http://www.gemtec.ca>
>>>>> /191 Doak Road
>>>>> Fredericton, NB, Canada
>>>>> E3C 2E6
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> *Andrew DeMerchant*
>>> fax 506-453-9470
>>> /191 Doak Road
>>> E3C 2E6
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
