[mapguide-users] Query String Auto-Login with Fusion or
Flexible Layouts
Andy Morsell
amorsell at spatialgis.com
Thu Aug 7 15:18:41 EDT 2008
No, that does not work with Fusion. There were some threads on this a
couple of months ago that might be worth perusing. The short of it is that
if you call a Fusion appDef from the file system, it uses the hardcoded
Anonymous user so there will be no prompting, etc. So, no need to API
create a &Session. However, if you are calling the appDef from the
repository, then MGOS does it own authentication in which case you would
need to pass the session as credentials.
Andy Morsell, P.E.
Spatial Integrators, Inc.
www.SpatialGIS.com
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rock Beans
Sent: Thursday, August 07, 2008 11:53 AM
To: MapGuide Users Mail List
Subject: [mapguide-users] Query String Auto-Login with Fusion or Flexible
Layouts
Using the old standard AJAX viewer you could add
&USERNAME=Anonymous&PASSWORD= to the URL allowing no login box to pop up.
Can this be done with the new Fusion based viewer without having to API
create a &Session?
The Rock
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080807/23230acb/attachment.html
