[mapguide-users] trouble replicating interstate symbol definition
Jonathan Manafi
jonathan.manafi at cctechnol.com
Thu Aug 7 15:57:18 EDT 2008
Martin,
I appreciate all the help that you have given. I have located an
Autodesk white paper on the subject that I am currently using to create
a path symbol for the interstate. For anyone else's reference, it is
located at
http://www.rand.com/imaginit/1/pdfs/technology/software/building_symbol_libraries_with_autodesk_mapguide_enterprise_2009.pdf.
In there, it does state that 1.2 should be able to handle definitions
for highway shields.
I would be curious if anyone still using MGOS 1.2 and symbol
definitions, or a developer, would be able to use the image I have
provided to successfully create a symbol definition. Perhaps 1.2 has
issues accessing stored images? Everything created by paths so far has
worked with no problems.
Thanks again for the help.
Martin Morrison wrote:
> You do realize I only sent you the symbol definition part of the file,
> I didn't send the complete file. You will insert the section I sent
> in place of your symbol definition in your file. You need the rest of
> your file. There is a white paper by Autodesk that explains the whole
> process quite well. A brief look at their site did not turn it up
> though. Can one of the Adesker's chime in with a link to the
> whitepaper on composite symbols?
> Martin
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of
> *Jonathan Manafi
> *Sent:* Thursday, August 07, 2008 1:20 PM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] trouble replicating interstate symbol
> definition
> Hmm...I just tried that as well, and the process worked, in that it
> created a symbol with that information. However, when I tried using it
> on the map, it again displayed nothing for me.
> One other question Martin: When I tried uploading the xml to the
> server, I got an error message with an exception thrown with a
> validation error message. I had received that in Studio as well,
> because <SimplSymbolDefinition> needs a 'version=1.0.0' attribute. So,
> I included that, but I still got an error. It wasn't until I had
> declared at the top of the file
> <?xml version="1.0" encoding="UTF-8"?>
> <SimpleSymbolDefinition
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> <http://www.w3.org/2001/XMLSchema-instance>
> xsi:noNamespaceSchemaLocation="SymbolDefinition-1.0.0.xsd"
> version="1.0.0">
> that I got it load to the server. Did you never have to go through
> this in order to save your files?
> Thanks.
> The exact error message was
> An exception occurred in the XML parser.
> An exception occurred in the XML parser. Exception occurred in method
> MgResourceContentManager.ValidateDocument at line 556 in file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ResourceContentManager.cpp
> I created the symbols outside of Studio using a text editor and then
> loaded them into the server. I will say that the first attempt or two
> at using online encoders to base64 didn't work the file was radically
> different that what was shown below. I did hit on one that worked
> well, I have it bookmarked but I don't have access to that bookmark
> right now. You can look at the symbols created by the xml below by
> going to http://gis.edsi/com then follow the links to the Mecklenburg
> County public site.
> Thanks,
> Martin
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080807/1ec91ca2/attachment.html
