[mapguide-users] query in sheboygan is not working
Tom Fukushima tom.fukushima at autodesk.com
Thu Aug 7 19:41:00 EDT 2008
The online version is running 1.2 and there were some breaking API changes with the coordinate system API in 2.0 (see http://trac.osgeo.org/mapguide/wiki/Release/2.0/Notes) so that's why the online version works, but yours doesn't.  You will probably need to change the PHP scripts so that "new MgCoordinateSystemTransform" is not used.
BTW, to help you debug these PHP pages, you should turn the PHP error logging on in the php.ini file found in the WebServerExtensions/Php directory.  Search for the line that starts with display_errors (not "; - display_errors" because that's a comment line) and change it to display_errors = on.  You may have to restart your web server.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of oamram
Sent: Thursday, August 07, 2008 5:12 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] query in sheboygan is not working
Hi All,
new to this, i installed mapguide 2 and it works great.
however the query function does not work at all.
any suggestion on how to solve it?
i also download the redding package and the query does not work, how on the
online version of the
of the redding application the query function does work.
much appriciated , Omer.
View this message in context: http://www.nabble.com/query-in-sheboygan-is-not-working-tp18881736p18881736.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
