[mapguide-users] wrong file names in DevGuideSamples.zip
Sylvain Pasche
sylvain.pasche at camptocamp.com
Mon Aug 11 10:19:44 EDT 2008
In the DevGuideSamples.zip archive, available at
http://download.osgeo.org/mapguide/releases/2.0.1/samples/DevGuideSamples.zip,
all the file names are in upper case.
However, the .html or .php files require some file to be in mixed case.
For getting the PHP samples to work on Linux, I did the following:
Convert all file names to lower case, and modify the files :
cd /usr/local/mapguideopensource/webserverextensions/www/phpsamples
mv styles/globalstyles.css styles/globalStyles.css
mv styles/otherstyles.css styles/otherStyles.css
mv common/pageloadfunctions.js common/pageLoadFunctions.js
mv common/title.php common/Title.php
Maybe there are more files to adapt. It would be great to publish a .zip
file with the correct file names.
Sylvain
