[mapguide-users] Using .NET Api to connect from a different
Machine
Zac Spitzer
zac.spitzer at gmail.com
Mon Aug 11 13:13:33 EDT 2008
I have just hit this as well... using the java api with coldfusion.
Johann, can you file a bug?
z
On Fri, Jul 18, 2008 at 12:21 AM, Kenneth Skovhede, GEOGRAF A/S
<ks at geograf.dk> wrote:
> AFAIK, it should work then.
> Do you have both port 2812 and 2811 open on both machines?
> Since you are using .Net, you could also use the Web API.
> I have wrapped most of the calls in the MaestroAPI, so they appear to be
> native .Net classes:
> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Johann Nothbauer skrev:
>> Hi Kenneth!
>> Thank you for your fast answer.
>> I already changed the IpAdress in the "webconfig.ini" file. The
>> MGSiteConnection works perfectly. It's the Resource-Service that I can't
>> connect to (MgConnectionFailedException). Do you know which files I have to
>> copy for to use the Resource Service?
>> Thany yo for the warning, I am absolutely aware of the security issues. My
>> solution is designed for administrative access over local LAN only.
>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>> The file "webconfig.ini" must be changed to point to the correct server
>>> instead of "127.0.0.1".
>>> Its under the section [SiteConnectionProperties]
>>> IpAddress =127.0.0.1
>>> Port = 2812
>>> You might also have to copy some of the folders referenced in there,
>>> depending on what you want to do.
>>> I would not recommend doing this over the internet, because the data
>>> transmitted over the wire ends up in the MapGuide server process which runs
>>> in the "Local System Account".
>>>> Hi all!
>>>> I'm trying to use the .NET Api to establish a connection to a Mapguide
>>>> 2.0.1 Site without using a Web Viewer. My Application is a smart client and
>>>> should run on a different Machine the MapGuide Server runs on.
>>>> So I tried the following (in a Winforms Button_Click):
>>>> MapGuideApi.MgInitializeWebTier("webconfig.ini");
>>>> // Connect to the site.
>>>> MgUserInformation userInfo = new MgUserInformation("Administrator",
>>>> "admin");
>>>> MgSiteConnection siteConnection = new MgSiteConnection();
>>>> siteConnection.Open(userInfo);
>>>> MgResourceService resService =
>>>> (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
>>>> This works so far, but when I try to use the Resource-Service like this:
>>>> MgResourceIdentifier resID = new MgResourceIdentifier("Library://");
>>>> MgByteReader resEnum = resService.EnumerateResources(resID, -1, "");
>>>> the API throws get an "OSGeo.MapGuide.MgConnectionFailedException"
>>>> (Message: "Cannot establish connection").
>>>> The same code works on the MapGuide Server Machine.
>>>> Is it possible to use the API to connect to a Mapguide Server on a
>>>> different machine? Or do I have to use the Web-API (XML) over HTTP? I can
>>>> change all my firewall rules, no problem.
>>>> Any Ideas?
>>>> Thanx,
>>>> Nothi
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
