[mapguide-users] DWF EPLOT Only one Layer can be selectable
andhave data
Rock Beans
rockbeans at gmail.com
Tue Aug 12 10:14:53 EDT 2008
Same issue here. Is there a solution or work around to this bug? If this bug
is not reported and it is not the fault of the DWF viewer I would create a
ticket on this Scott.
The Rock
On Mon, Aug 11, 2008 at 4:33 PM, Berdel, Brian <brian.berdel at mcmtrans.com>wrote:
> I am experiencing the same issue.
> Thanks,
> Brian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Scott
> Hameister
> Sent: Monday, August 11, 2008 3:51 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] DWF EPLOT Only one Layer can be selectable
> andhave data
> I Went through and Used the Plot to DWF code "EPLOT.PHP" to create DWF
> output.
> My DWF opens just fine....However a few Odd things in their
> behaviour....It
> only allows me to have one layer that is selectable for getting Object
> Properties from.
> In my map I have PLSS/Section corners that are selectable and Data is
> Displayable in the AJAX viewer, same With my Parcels Layer...When i
> publish
> to DWF only the Top most (PLSS corners) layer is ever published as
> selectable and having Object Properties on it...I moved the Parcels to
> the
> top then they worked and the PLSS corners didnt, even with only the PLSS
> corners layer on.
> So I did an advanced search on The PLSS corners by an ID and Voila its
> in
> the DWF, but when i click on the Object hyperlink it wont zoom to that
> feature, i do an advanced search on parcels and the Hyperlink works...Is
> this a bug in the $mappingService->GeneratePlot Code?
> http://www.nabble.com/DWF-EPLOT-Only-one-Layer-can-be-selectable-and-hav
> e-data-tp18932394p18932394.html<http://www.nabble.com/DWF-EPLOT-Only-one-Layer-can-be-selectable-and-have-data-tp18932394p18932394.html>
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080812/46b143fd/attachment.html
