[mapguide-users] Tooltip on the marker
gracecwl gracecwl at sains.com.my
Tue Aug 12 20:26:44 EDT 2008
Hi Kenneth,
I no fill out resourceID because i create new 'temporary layer' like in
sheboygan example.
I have try with column name but still same problem- no output.
I cant try with load the layer manually, since that is a new  temporary
layer.However, i try the tooltip state ment in manual load without any
problem.
thanks and regards,
grace
Kenneth Skovhede, GEOGRAF A/S wrote:
> I assume you fill out the resourceID somehow.
> Although it should work with just a string constant, have you tried with
> a column name?
> I'm not sure if tooltips work on data with no primary key, have you
> tried it on data where there is a primary key?
> If you try to load the layer manually, and open it in Studio or Maestro,
> with a real data source, does that work then?
> Regards, Kenneth Skovhede, GEOGRAF A/S
> gracecwl skrev:
>> Hi all,
>> I try the method suggested, however, i cant get the desired output.
>> May i know what happen. attached is my .xml file.
>> http://www.nabble.com/file/p18937171/parcelmarker.xml parcelmarker.xml
>> Farah-2 wrote:
>>> Hi..!
>>> It is possible to create tooltips for the pushpin markers. All u need to
>>> do
>>> is modify your layer xml file.
>>> You need to add:
>>> <ToolTip> Property Name</ToolTip>
>>> In your layer.xml file.
>>> Regards
>>> Farah
>>> -----Original Message-----
>>> From: Kencana [mailto:bluesky_dyx at hotmail.com]
>>> Sent: Monday, November 06, 2006 8:45 AM
>>> To: users at mapguide.osgeo.org
>>> Subject: [mapguide-users] Tooltip on the marker
>>> hi all,
>>> is that possible to create tooltip for the markers(push pin) just like
>>> when
>>> we add a tooltip features on a layer using mapguide studio?
>>> I am looking forward for the reply and thank you for the guidance..
>>> Regards,
>>> Kencana
>>> View this message in context:
>>> http://www.nabble.com/Tooltip-on-the-marker-tf2580163.html#a7192696
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Tooltip-on-the-marker-tp7192696p18954920.html
