[ZS0] Re: [mapguide-users] [ZS0] OGR provider for personal geodatabse
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Aug 13 02:56:23 EDT 2008
There were some instability issues previously (and there are still some
now) with the OGR provider.
Int the file "serverconfig.ini", try adding "OSGeo.OGR" to the
"DataConnectionPoolExcludedProviders".
I have not seen the problem you are describing before.
What version of MapGuide are you using?
Have you updated the FDO files?
Regards, Kenneth Skovhede, GEOGRAF A/S
Techswami skrev:
> When I select any feature on the layer the features disappears and get white
> background. After that even if I restart the application it cannot bring
> back the geometry.
> I had to restart MapGuide server every time to bring back the geometry
> The entire map becomes white?
> YES it become white
> The server crashes?
> No Server does not crash
> The map becomes blue?
> No Map does not becomes blue
> Tony
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> What exactly happens when you select a feature?
>> Techswami skrev:
>>> hi
>>> OGR provider works great for ESRI personal geodatabase(.mdbfile)  using
>>> OGR
>>> but if I  select any feature then the entire layer can not be viewed in
>>> the
>>> map. i tried latest patch also . it does the same thing.
>>> anyone has a same problem
>>> please help
>>> tony
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080813/69629ae9/attachment.html
